Acer X1126H SVGA 4000 Lumens DLP Projector
Quicklinx: DHQCWS00 Mfr#: MR.JPB11.002
Acer X1126H - DLP projector - portable - 3D
DLP projector
3D Capable
Yes (3D glasses sold separately)
Brightness
4000 lumens
Contrast Ratio
20000:1
Resolution
SVGA (800 x 600)
Native Aspect Ratio
4:3
Colour Support
1.07 billion colours
Bulb type
UHP 220 Watt
Bulb life cycle
Up to 4500 hour(s) - normal mode , Up to 15000 hour(s) - economic mode
Video Input
RGB, S-Video, composite video (PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G)
Video Modes
480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Speakers
Speaker(s) - integrated
AC 120/230 V
260 Watt
31.5 cm x 21.4 cm x 9.8 cm
2.6 kg
DLP projector
3D Capable
Projector
Brightness
4000 lumens
Brightness (Reduced)
3200 lumens
Contrast Ratio
20000:1
Image Size
58 cm - 762 cm
Projection Distance
1 m - 11.8 m
Throw Ratio
1.94 - 2.16:1
Uniformity
85 %
Digital Zoom Factor
2x
Resolution
SVGA - SVGA (800 x 600) (native) / 1920 x 1200 (resized)
Native Aspect Ratio
4:3
Colour Support
Max Sync Rate (V x H)
120 Hz x 100 kHz
Bulb type
UHP 220 Watt
Bulb life cycle
6-segment colour wheel, DLP 3D Ready, SmartFormat Technology, 16:9 aspect ratio support, EcoProjection Technology, Acer ColorSafe II Technology, Quick-Start, ColorBoost 3D Technology, Acer LumiSense+
Lens
Focus Type
Manual
Lens Aperture
F/2.41-2.53
Zoom Type
Manual
Zoom Factor
1.1x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-40 / +40
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video, MHL
Video Modes
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
3 Watt
Speakers
1 x mixed channel
1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 2 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x HDMI - 19 pin HDMI Type A , 1 x Mobile High-Definition Link (MHL) / HDMI , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232 - 9 pin D-Sub (DB-9) (management) , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x USB - 4 pin USB Type A
Security Features
Power Source
AC
AC 120/230 V
260 Watt
31.5 cm
21.4 cm
9.8 cm
2.6 kg
0 - 80%
Sound Emission
32 dBA
24 dBA
