- Acer X1126H - DLP projector - portable - 3D
- DLP projector
- 3D Capable
- Yes (3D glasses sold separately)
- Brightness
- 4000 lumens
- Contrast Ratio
- 20000:1
- Resolution
- SVGA (800 x 600)
- Native Aspect Ratio
- 4:3
- Colour Support
- 1.07 billion colours
- Bulb type
- UHP 220 Watt
- Bulb life cycle
- Up to 4500 hour(s) - normal mode , Up to 15000 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video (PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G)
- Video Modes
- 480p, 720p, 1080i, 1080p, 480i, 576i, 576p
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V
- 260 Watt
- 31.5 cm x 21.4 cm x 9.8 cm
- 2.6 kg
- 2-year warranty
- DLP projector
- 3D Capable
Projector
- Brightness
- 4000 lumens
- Brightness (Reduced)
- 3200 lumens
- Contrast Ratio
- 20000:1
- Image Size
- 58 cm - 762 cm
- Projection Distance
- 1 m - 11.8 m
- Throw Ratio
- 1.94 - 2.16:1
- Uniformity
- 85 %
- Digital Zoom Factor
- 2x
- Resolution
- SVGA - SVGA (800 x 600) (native) / 1920 x 1200 (resized)
- 4:3
- Colour Support
- Max Sync Rate (V x H)
- 120 Hz x 100 kHz
- Bulb type
- UHP 220 Watt
- Bulb life cycle
- 6-segment colour wheel, DLP 3D Ready, SmartFormat Technology, 16:9 aspect ratio support, EcoProjection Technology, Acer ColorSafe II Technology, Quick-Start, ColorBoost 3D Technology, Acer LumiSense+
Lens
- Focus Type
- Manual
- Lens Aperture
- F/2.41-2.53
- Zoom Type
- Manual
- Zoom Factor
- 1.1x
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -40 / +40
Video Input
- TV System
- PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video, S-Video, MHL
- Video Modes
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 3 Watt
- Speakers
- 1 x mixed channel
- 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 2 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x HDMI - 19 pin HDMI Type A , 1 x Mobile High-Definition Link (MHL) / HDMI , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232 - 9 pin D-Sub (DB-9) (management) , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x USB - 4 pin USB Type A
- Security Features
- Power Source
- AC
- Voltage Required
- AC 120/230 V
- 260 Watt
- 31.5 cm
- 21.4 cm
- 9.8 cm
- 2.6 kg
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 0 - 80%
- Sound Emission
- 32 dBA
- Sound Emission (Economic Mode)
- 24 dBA
