The compact Veriton X series desktop packs powerful components and advanced technologies to handle the most challenging office tasks. The PC also features ample support and security for the company network. The modular, tool-less design makes accessibility easy, and energy-efficient certifications signify cost savings and care for the environment.
Compact and efficient
The Veriton X series takes care of all your business needs, while preserving precious office space. You'll also appreciate the easy-to-use, modular design and toolless accessibility. -
High-tech management tools
This series' high-tech management tools improve system support, maintenance and monitoring of company assets, while reducing desk-side visits. The PC supports automatic incremental backups and prevents unauthorized access to your machine. -
Manageability solutions
The Veriton control center has handy utilities for optimizing energy settings, instantly loading frequently used applications, transferring data and personal settings to another PC seamlessly, and protecting your data from threats. What's more, Acer offers management solutions for remote management of common IT tasks.
- Acer Veriton X6 VX6640G - SFF - Core i7 6700 3.4 GHz - 8 GB - HDD 1 TB
- Personal computer - small form factor
- Localisation
- Region: United Kingdom
- Processor
- Intel Core i7 (6th Gen) 6700 / 3.4 GHz (4 GHz) (Quad-Core)
- Processor Socket
- LGA1151 Socket
- Cache Memory
- 8 MB L3 Cache
- Cache Per Processor
- 8 MB
- RAM
- 8 GB (installed) / 32 GB (max) - DDR4 SDRAM
- Storage Controller
- SATA
- Hard Drive
- HDD 1 TB - SATA 6Gb/s - 7200 rpm
- Optical Storage
- DVD SuperMulti
- Card Reader
- Graphics Controller
- PCIe x16 - NVIDIA GeForce GT 705
- Video Memory
- 1 GB
- Audio Output
- 5.1 channel surround
- Networking
- GigE
- Power
- AC 120/230 V
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition / Windows 10 Pro 64-bit Edition Dual Load
- 10 cm x 35.4 cm x 26.5 cm
- 6 kg
- Personal computer
- Product Form Factor
- Small form factor
- Localisation
Processor / Chipset
- CPU
- Clock Speed
- 3.4 GHz
- Max Turbo Speed
- 4 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Socket
- LGA1151 Socket
- Chipset Type
- Intel Q170
Cache Memory
- Installed Size
- L3 Cache - 8 MB
- 8 MB
RAM
- Installed Size
- 8 GB / 32 GB (max)
- Technology
- DDR4 SDRAM
- Effective Memory Speed
- 2133 MHz
- Form Factor
- DIMM 288-pin
- Unbuffered
- Configuration Features
- 1 x 8 GB
Hard Drive
- HDD
- Capacity
- 1 x 1 TB
- Interface Type
- SATA 6Gb/s
- Spindle Speed
- 7200 rpm
Storage Controller
- 1 x SATA
Optical Storage
- DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Card Reader
- Card reader
- Supported Flash Memory Cards
- SD Memory Card
Monitor
- Monitor Type
- None.
Graphics Controller
- Interface Type
- PCIe x16
- Graphics Processor
- Video Memory
- 1 GB
- Video Interfaces
- DVI, HDMI
Audio Output
- Sound Output Mode
- High Definition Audio
Input Device
- Mouse, keyboard
Keyboard
- Interface
- USB
Mouse
- Interface
- USB
- Ethernet Controller
- Intel I219-LM
- Data Link Protocol
- Bays
- External 5.25" , Internal 3.5"
- Slots
- 1 (total) / 0 (free) x CPU , DIMM 288-pin , 1 PCIe x1 , 1 PCIe x16
- 4 x USB 3.0 (2 front, 2 rear) , 6 x USB 2.0 (2 front, 4 rear) , 2 x microphone (1 front, 1 rear) , 2 x audio line-out/headphones (1 front, 1 rear) , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x audio line-in , 1 x LAN (Gigabit Ethernet) , 1 x HDMI , 1 x DVI
- RoHS, EuP
- Power supply
- Voltage Required
- AC 120/230 V
- Power Provided
- 220 Watt
- Efficiency
- 82%+
- Power Factor Correction
- Yes (active)
Operating System / Software
- OS Provided
- 10 cm
- 35.4 cm
- 26.5 cm
- 6 kg
