The Veriton Z houses a Full HD webcam that rotates up to 180º from front-facing to rear-facing, requiring only the tap of a hotkey to flip the image. Flip it from 0º to 90º to capture everyone in a video conference or to 180º to capture a customer's picture. The webcam also retracts to provide better security by preventing unnecessary exposure of your office.
Intel Core processor provides impressive performance, for seamless productivity. The Full HD display with IPS technology delivers clear views from all angles. Attach an additional monitor via HDMI to expand your view and multitask efficiently.
Best business webcam
The Veriton Z houses a Full HD webcam that rotates up to 180º from front-facing to rear-facing, requiring only the tap of a hotkey to flip the image. Flip it from 0º to 90º to capture everyone in a video conference or to 180º to capture a customer's picture. The webcam also retracts to provide better security by preventing unnecessary exposure of your office. -
Fits all environments
This all-in-one sports an ErgoStand that allows it to fit in any environment. It can fluidly pivot from landscape to portrait orientation, swivel 120º, tilt from -5º to 35º, and its height can be adjusted by as much as 150 mm. The Veriton Z can also be wall-mounted (VESA) to save even more space. -
Work fast
- Acer Veriton Z4710G_Wtub - all-in-one - Core i3 4170 3.7 GHz - 4 GB - HDD 500 GB - LED 21.5"
- Personal computer - all-in-one
- Localisation
- Region: United Kingdom
- Processor
- Intel Core i3 (4th Gen) 4170 / 3.7 GHz (Dual-Core)
- Processor Socket
- LGA1150 Socket
- Cache Memory
- 3 MB
- Cache Per Processor
- 3 MB
- RAM
- 4 GB (installed) / 16 GB (max) - DDR3L SDRAM
- Storage Controller
- SATA
- Hard Drive
- HDD 500 GB - SATA 6Gb/s - 7200 rpm
- Optical Storage
- DVD SuperMulti
- Card Reader
- Monitor
- 21.5" - LED - 1920 x 1080 (Full HD)
- Graphics Controller
- Intel HD Graphics 4400
- Networking
- GigE, 802.11a, 802.11b/g/n, Bluetooth 4.0
- Power
- AC 120/230 V
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition / Windows 10 Pro 64-bit Edition Dual Load
- 41.5 cm x 6.88 cm x 53.24 cm
- 8.5 kg
- Personal computer
- Product Form Factor
- All-in-one - with stand
- Embedded Security
- Trusted Platform Module (TPM 1.2) Security Chip
- Localisation
Processor / Chipset
- CPU
- Clock Speed
- 3.7 GHz
- Number of Cores
- Dual-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Socket
- LGA1150 Socket
- Chipset Type
- Intel H81
Cache Memory
- Installed Size
- 3 MB
- 3 MB
RAM
- Installed Size
- 4 GB / 16 GB (max)
- Technology
- DDR3L SDRAM
- Effective Memory Speed
- 1600 MHz
- Form Factor
- SO-DIMM 204-pin
- Configuration Features
- 1 x 4 GB
Hard Drive
- HDD
- Capacity
- 1 x 500 GB
- Interface Type
- SATA 6Gb/s
- Spindle Speed
- 7200 rpm
Storage Controller
- 1 x SATA
Optical Storage
- DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Card Reader
- Card reader
Monitor
- Monitor Type
- LED
- Diagonal Size
- 21.5"
- Native Resolution
- Widescreen Display
- Response Time
- 5 ms
- Image Brightness
- 250 cd/m²
- Image Contrast Ratio
- 1000:1
- Monitor Features
- Anti-glare
Graphics Controller
- Graphics Processor
- Video Interfaces
- VGA, HDMI
Audio Output
- Speakers Included
- 2 x right / left channel
Camera
- Resolution (MP)
- 2 Megapixel
Input Device
- Mouse, keyboard
Keyboard
- Interface
- USB
Mouse
- Interface
- USB
- Wireless LAN Supported
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, Bluetooth 4.0
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, Bluetooth 4.0
- Slots
- 1 (total) / 0 (free) x CPU , SO-DIMM 204-pin
- 2 x USB 3.0 , 4 x USB 2.0 , 1 x HDMI , 1 x VGA
- Power adapter
- Voltage Required
- AC 120/230 V
- Power Provided
- 150 Watt
- Power Factor Correction
- Yes (active)
Operating System / Software
- OS Provided
- 41.5 cm
- 6.88 cm
- 53.24 cm
- 8.5 kg
