Product
Acer Veriton X2640G SFF i3-7100 4GB 500GB Win 10 Pro 64-bit
Upgrade your old device for up to £200 rewards
Cashback
Quicklinx: DQMVWS00 Mfr#: DT.VPUEK.020
  • Core i3
The Veriton 2 series delivers excellent multitasking performance to optimize your productivity. Tool-less expandability, a selection of affordable solutions, and other useful features efficiently handle your daily work needs. With support for WOL, PXE and more, the Veriton 2 series is simple to manage.
  • Form and function
  • Vital security
Acer Veriton X2640G - DTS - Core i3 7100 3.9 GHz - 4 GB - 500 GB
Personal computer - desktop slimline
Region: United Kingdom
1 x Intel Core i3 (7th Gen) 7100 / 3.9 GHz (Dual-Core)
Processor Socket
LGA1151 Socket
Cache Memory
3 MB
Cache Per Processor
3 MB
RAM
4 GB (installed) / 16 GB (max) - DDR4 SDRAM
Storage Controller
SATA
Hard Drive
1 x 500 GB - SATA 6Gb/s - 5400 rpm
Optical Storage
DVD-Writer
Graphics Controller
Intel HD Graphics 630
Audio Output
5.1 channel surround
GigE
AC 120/230 V
OS Provided
Windows 10 Pro 64-bit Edition
10 cm x 35.4 cm x 26.5 cm
6 kg
Environmental Standards
ENERGY STAR Qualified
Personal computer
Product Form Factor
Desktop slimline
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
CPU
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
CPU Socket
LGA1151 Socket
Chipset Type
Intel H110 Express
Cache Memory
Installed Size
3 MB
Cache Per Processor
3 MB
RAM
Installed Size
4 GB / 16 GB (max)
DDR4 SDRAM
Effective Memory Speed
2400 MHz
Rated Memory Speed
2400 MHz
DIMM 288-pin
Unbuffered
Configuration Features
1 x 4 GB
Hard Drive
HDD
1 x 500 GB
Interface Type
SATA 6Gb/s
Spindle Speed
5400 rpm
Storage Controller
1 x SATA
Optical Storage
DVD-Writer - SATA
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Video Interfaces
VGA, DVI
Audio Output
Sound Output Mode
High Definition Audio
Input Device
Mouse, keyboard
Keyboard
USB
Mouse
USB
Ethernet Controller
Realtek RTL8111E
Bays
Internal 3.5" , External 5.25"
Slots
1 (total) / 0 (free) x CPU , DIMM 288-pin , 1 PCIe x1 , 1 PCIe x16
4 x USB 2.0 (2 front, 2 rear) , 4 x USB 3.0 (2 front, 2 rear) , 1 x LAN (Gigabit Ethernet) , 2 x microphone (1 in front) , 2 x audio line-out/headphones (1 in front) , 1 x audio line-in , 1 x serial , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x DVI , 1 x VGA
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
VCCI, CB, FCC, RoHS, PC 2001, EuP
Power supply
Nominal Voltage
AC 120/230 V
Power Provided
220 Watt
Efficiency
82%+
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
ENERGY STAR Certified
10 cm
35.4 cm
26.5 cm
6 kg
DQMV Crucial 32GB Kit (16GBx2) DDR4 2400 MT/s (PC4-19200) CL17 DR x8 Unbu In Stock £157.62
