The Veriton 2 series delivers excellent multitasking performance to optimize your productivity. Toolless expandability and other useful features efficiently handle your daily work needs. With support for WOL, PXE and more, the Veriton 2 series is simple to manage.
Form and function
The Veriton 2 series delivers excellent multitasking performance to optimize your productivity. Tool-less expandability, a selection of affordable solutions, and other useful features efficiently handle your daily work needs. -
Vital security
- Acer Veriton X2 VX2640G - SFF - Core i3 6100 3.7 GHz - 4 GB - HDD 500 GB
- Personal computer - small form factor
- Localisation
- Region: United Kingdom
- Processor
- Intel Core i3 (6th Gen) 6100 / 3.7 GHz (Dual-Core)
- Processor Socket
- LGA1151 Socket
- Cache Memory
- 3 MB L3 Cache
- Cache Per Processor
- 3 MB
- RAM
- 4 GB (installed) / 16 GB (max) - DDR4 SDRAM
- Storage Controller
- SATA
- Hard Drive
- HDD 500 GB - SATA 6Gb/s - 7200 rpm
- Optical Storage
- DVD SuperMulti
- Card Reader
- Graphics Controller
- Intel HD Graphics 530
- Networking
- GigE
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition / Windows 10 Pro 64-bit Edition Dual Load
- 10 cm x 35.4 cm x 26.5 cm
- 6 kg
- Personal computer
- Product Form Factor
- Small form factor
- Localisation
Processor / Chipset
- CPU
- Clock Speed
- 3.7 GHz
- Number of Cores
- Dual-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Socket
- LGA1151 Socket
- Chipset Type
- Intel H110 Express
Cache Memory
- Installed Size
- L3 Cache - 3 MB
- 3 MB
RAM
- Installed Size
- 4 GB / 16 GB (max)
- Technology
- DDR4 SDRAM
- Effective Memory Speed
- 2133 MHz
- Form Factor
- DIMM 288-pin
- Unbuffered
- Configuration Features
- 1 x 4 GB
Hard Drive
- HDD
- Capacity
- 1 x 500 GB
- Interface Type
- SATA 6Gb/s
- Spindle Speed
- 7200 rpm
Storage Controller
- 1 x SATA
Optical Storage
- DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Card Reader
- Card reader
- Supported Flash Memory Cards
- SD Memory Card
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Video Interfaces
- VGA, DVI
Input Device
- Mouse, keyboard
Keyboard
- Interface
- USB
Mouse
- Interface
- USB
- Data Link Protocol
- Bays
- Internal 3.5" , External 5.25"
- Slots
- 1 (total) / 0 (free) x CPU , DIMM 288-pin , 1 PCIe x1 , 1 PCIe x16
- 4 x USB 2.0 (2 front, 2 rear) , 4 x USB 3.0 (2 front, 2 rear) , 1 x LAN (Gigabit Ethernet) , 2 x microphone (1 in front) , 2 x audio line-out/headphones (1 in front) , 1 x audio line-in , 1 x serial , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x DVI , 1 x VGA
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- EuP
- Power supply
- Voltage Required
- Power Provided
- 220 Watt
- Efficiency
- 82%+
- Power Factor Correction
- Yes (active)
Operating System / Software
- OS Provided
- 10 cm
- 35.4 cm
- 26.5 cm
- 6 kg
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.09 |
