Product
Acer Veriton VX4650G SFF i5-7500 8GB 256GB SSD Windpws 10 Pro 64-bit
Quicklinx: D6M9WS00 Mfr#: DT.VPYEK.002
Processor Type: Core i5
Operating System: Windows 10 Pro 64-bit Edition
Installed Memory: 8GB
Hard Drive Capacity: 256GB
Storage Type: SSD
  • Core i5
£598.05 ex VAT
£717.66 inc VAT
This PC is compact, but won't compromise on performance and expandability. With great manageability and security features, you'll be sure everything is under control.
  • A space saver
    The compact chassis helps to free up precious desktop space.
  • Use with multiple displays
    With advanced graphics, the Acer Veriton X can support up to three independent displays.
Acer Veriton X4650G - SFF - Core i5 7500 3.4 GHz - 8 GB - 256 GB
Personal computer - small form factor
Region: United Kingdom
1 x Intel Core i5 (7th Gen) 7500 / 3.4 GHz (3.8 GHz) (Quad-Core)
Processor Socket
LGA1151 Socket
Processor Main Features
Intel Turbo Boost Technology 2, Intel Smart Cache
Cache Memory
6 MB
Cache Per Processor
6 MB
RAM
8 GB (installed) / 64 GB (max) - DDR4 SDRAM - non-ECC
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
1 x SSD 256 GB
Optical Storage
DVD-Writer
Graphics Controller
Intel HD Graphics 630
GigE
AC 120/230 V
OS Provided
10 cm x 39.21 cm x 26.7 cm
6 kg
Personal computer
Product Form Factor
Small form factor
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
CPU
Max Turbo Speed
3.8 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Socket
LGA1151 Socket
Chipset Type
Intel B250 Express
Cache Memory
Installed Size
6 MB
Cache Per Processor
6 MB
RAM
Installed Size
8 GB / 64 GB (max)
Effective Memory Speed
2400 MHz
Rated Memory Speed
2400 MHz
DIMM 288-pin
Slots
4 (Total) / 3 (empty)
Unbuffered
Configuration Features
1 x 8 GB
Hard Drive
SSD
1 x 256 GB
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Optical Storage
DVD-Writer - SATA
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Video Interfaces
VGA, DVI, HDMI
Input Device
Keyboard
Keyboard
USB
Ethernet Controller
Realtek RTL8111EPV
Bays
1 (total) / 0 (free) x external 5.25" x 1/2H , 1 internal 3.5" x 1/3H
Slots
1 (total) / 0 (free) x CPU , 1 PCIe x1 , 1 PCIe x16 , 4 (total) / 3 (free) x DIMM 288-pin
4 x USB 2.0 (2 front, 2 rear) , 6 x USB 3.0 (2 front, 4 rear) , 2 x microphone (1 front, 1 rear) , 2 x audio line-out/headphones (1 front, 1 rear) , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x audio line-in , 1 x serial , 1 x LAN (Gigabit Ethernet) , 1 x HDMI , 1 x VGA , 1 x DVI
M.2 SSD vertical bracket
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
EuP
Power supply
Nominal Voltage
AC 120/230 V
Power Provided
220 Watt
Efficiency
82%+
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
10 cm
39.21 cm
26.7 cm
6 kg
Acer Veriton VX4650G SFF i5-7500 8GB 256GB SSD Windpws 10 Pro 64-bit Bundle deal on Acer Veriton VX4650G SFF i5-7500 8GB 256GB SSD Windpws 10 Pro 64-bit
£781.77
saving £8.33
£695.04
Storage Type: SSD
Processor Model: I5-7500
Type: Personal computer
Case Style: Desktop
Optical Storage: DVD-Writer
Brand: Acer
Price Range Ex VAT: 500 - 750
