Smoothly and quickly view and edit large spreadsheets, presentations and video. With higher performance and lower power, DDR4 2666MHz memory and the SATA SSD give accelerated access to files and the operating system.
Expand the functionality with a host of ports to connect almost any secondary device. The six USB ports front and back, a legacy VGA port, a modern HDMI port and a Gigabit LAN Ethernet port allow it to operate in many office environments.
Trusted Platform Module is serious security for any business that is serious about security. Trusted Platform Module (TPM) 2.0 securely stores authentication passwords, certificates or encryption keys on this integrated chip. Additional security is provided by Acer ProShield, a chassis key lock and a Kensington Lock hole.
In wireless offices it's important to have PCs capable of fast Wi-Fi access. The integrated 802.11ac wireless module provides slicker streaming and up to five times faster download speeds than 802.11n.
Powerful Performance
Heavy-duty performance for all the programs you need to work. No lag nor freezing of large spreadsheets, multiple presentations or when editing large graphics. With up to the latest Intel 8th Gen Core i7/i5/i3 processors and optional NVIDIA GeForce graphics card. -
Faster File Access
Smoothly and quickly view and edit large spreadsheets, presentations and video. With higher performance and lower power, DDR4-2666 MHz Memory and the SATA SSD give accelerated access to files and the operating system. -
Ports for All Occasions
Expand the functionality with a host of ports to connect almost any secondary device. The six USB ports front and back, a legacy VGA port, a modern HDMI port and a Gigabit LAN Ethernet port allow it to operate in many office environments. -
Business Grade Security
Trusted Platform Module is serious security for any business that is serious about security. Trusted Platform Module (TPM) 2.0 securely stores authentication passwords, certificates or encryption keys on this integrated chip. Additional security is provided by Acer ProShield, a chassis key lock and a Kensington Lock hole. -
Easy Fleet Management
Two dedicated applications make it easier for IT managers to control and gather information about the computers under their control. Acer Office Manager is an endpoint management solution used to deploy security policies, monitor IT assets and schedule maintenance tasks from one simple application and Acer Control Center (ACTC) is a remote diagnostic tool. -
Faster Wireless Speeds
- Acer Veriton Essential ES2 VES2735G - MT - Core i3 8100 3.6 GHz - 8 GB - SSD 128 GB
- Personal computer - mini tower
- Localisation
- Region: United Kingdom
- Processor
- Intel Core i3 (8th Gen) 8100 / 3.6 GHz (Quad-Core)
- Processor Socket
- LGA1151 Socket
- Cache Memory
- 6 MB
- Cache Per Processor
- 6 MB
- RAM
- 8 GB (installed) / 32 GB (max) - DDR4 SDRAM
- Storage Controller
- SATA
- Hard Drive
- SSD 128 GB
- Optical Storage
- DVD-Writer
- Graphics Controller
- Intel UHD Graphics 630
- Networking
- GigE
- Power
- AC 120/230 V
- OS Provided
- Windows 10 Pro 64-bit Edition
- 16 cm x 30.6 cm x 34.8 cm
- 10 kg
- Personal computer
- Product Form Factor
- Mini tower
- Localisation
Processor / Chipset
- CPU
- Clock Speed
- 3.6 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Socket
- LGA1151 Socket
- Chipset Type
- Intel B365
Cache Memory
- Installed Size
- 6 MB
- 6 MB
RAM
- Installed Size
- 8 GB / 32 GB (max)
- Technology
- DDR4 SDRAM
- Effective Memory Speed
- 2400 MHz
- Rated Memory Speed
- 2666 MHz
- Form Factor
- DIMM 288-pin
- Unbuffered
- Configuration Features
- 1 x 8 GB
Hard Drive
- SSD
- Capacity
- 1 x 128 GB
- Manufacturer
- Kingston
Storage Controller
- 1 x SATA
Optical Storage
- DVD-Writer - SATA
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Video Interfaces
- VGA, HDMI
Input Device
- Mouse, keyboard
Keyboard
- Interface
- USB
Mouse
- Interface
- USB
- Ethernet Controller
- Realtek RTL8111H
- Data Link Protocol
- Bays
- 5.25" , 3.5"
- Slots
- 1 (total) / 1 (free) x PCIe x16
- 8 x USB , 1 x LAN (Gigabit Ethernet) , 2 x audio line-in/microphone (1 front, 1 rear) , 1 x audio line-out/headphones (1 rear) , 1 x audio line-in , 1 x HDMI , 1 x VGA , 1 x headphones/microphone (1 in front) , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x serial
- Included Accessories
- Thermal pad
- RoHS
- Power supply
- Voltage Required
- AC 120/230 V
- Power Provided
- 180 Watt
- Efficiency
- 82%+
- Power Factor Correction
- Yes (active)
Operating System / Software
- OS Provided
- 16 cm
- 30.6 cm
- 34.8 cm
- 10 kg
APC BACK-UPS BE650G2-UK 650VA 230V | In Stock | £100.21 |
APC BACK-UPS BE850G2-UK 850VA 230V USB | In Stock | £110.10 |
APC BACK UPS PRO BR650MI 650VA 6 Outlets | In Stock | £140.55 |
APC BACK UPS PRO BR900MI 900VA 6 Outlets | In Stock | £195.26 |
