Packing powerful components into a petite, diamond-shaped chassis that can stand alone or snap onto the back of select Acer monitors, the Veriton N series aces your computing needs, while preserving precious space.
Growing with your business
Build your desktop as you build your business with easily attachable 1 liter add-ons. -
Breathe easy
Designed for efficiency, the new ventilated chassis helps keep your Veriton N running cooler, longer. -
Ideal placement
Free up your workspace and work more effectively with the sturdy support of the VESA mount. -
Easy internal access
Simply slide open the chassis for quick access to the HDD, M.2 SSD, and memory without the hassle of additional tools.
- Acer Veriton N4 VN4660G - compact PC - Core i5 8400 2.8 GHz - 8 GB - 256 GB
- Personal computer - compact PC
- Localisation
- Region: United Kingdom
- Processor
- 1 x Intel Core i5 (8th Gen) 8400 / 2.8 GHz (4 GHz) (6-core)
- Processor Socket
- LGA1151 Socket
- Processor Main Features
- Intel Turbo Boost Technology 2
- Cache Memory
- 9 MB
- Cache Per Processor
- 9 MB
- RAM
- 8 GB (installed) / 32 GB (max) - DDR4 SDRAM
- Storage Controller
- SATA
- Hard Drive
- 1 x SSD 256 GB - M.2 2280
- Optical Storage
- No optical drive
- Graphics Controller
- Intel UHD Graphics 630
- Networking
- GigE, 802.11a, 802.11b/g/n, 802.11ac Wave 2, Bluetooth 5.0
- OS Provided
- Windows 10 Pro 64-bit Edition
- 19.2 cm x 20.4 cm x 3.32 cm
- 1.5 kg
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - 1 year - carry-in
- Personal computer
- Product Form Factor
- Compact PC
- Localisation
Processor / Chipset
- CPU
- Intel Core i5 (8th Gen) 8400 / 2.8 GHz
- Max Turbo Speed
- 4 GHz
- Number of Cores
- 6-core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Socket
- LGA1151 Socket
- Chipset Type
- Intel B360
Cache Memory
- Installed Size
- 9 MB
- 9 MB
RAM
- Installed Size
- 8 GB / 32 GB (max)
- Technology
- DDR4 SDRAM
- Effective Memory Speed
- 2666 MHz
- Rated Memory Speed
- 2666 MHz
- Form Factor
- SO-DIMM 260-pin
- Dual channel memory architecture
- Configuration Features
- 1 x 8 GB
Hard Drive
- SSD - M.2 2280
- Capacity
- 1 x 256 GB
- Manufacturer
- Micron
Storage Controller
- 1 x SATA
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Video Interfaces
- HDMI, DisplayPort
Audio Output
- High Definition Audio
Input Device
- Mouse, keyboard
Keyboard
- Interface
- USB
Mouse
- Interface
- USB
- Ethernet Controller
- Realtek RTL8111EPV
- Wireless LAN Supported
- Wireless NIC
- Intel Wireless-AC 9560
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac Wave 2, Bluetooth 5.0
- Remote Management Protocol
- DMI
- Wake on LAN (WoL), PXE support
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac Wave 2, Bluetooth 5.0
- Slots
- 1 (total) / 1 (free) x PCIe x16 , 3 M.2 Card
- 2 x USB 2.0 , 3 x USB 3.1 Gen 1 , 1 x USB 3.1 Gen 2 , 1 x USB-C 3.1 , 1 x LAN (Gigabit Ethernet) , 1 x HDMI , 1 x DisplayPort , 1 x headphones (1 in front) , 1 x microphone (1 in front) , 1 x VGA
- Included Accessories
- VESA mounting kit, 2x wireless aerials, ADP holder for VESA kit
- Theft/Intrusion Protection
- Security lock slot (cable lock sold separately), chassis intrusion alarm
- Security Slot Type
- Kensington security slot
- TUV GS, BSMI, CB, FCC, RoHS, PC 2001
- Power adapter
- Power Provided
- 90 Watt
Operating System / Software
- OS Provided
- ENERGY STAR Certified
- 19.2 cm
- 20.4 cm
- 3.32 cm
- 1.5 kg
