Acer Veriton N4660G Core i5-8400 8GB 256GB SSD Windows 10 Pro
Quicklinx: F3HVWS00 Mfr#: DT.VRDEK.026
Processor Type: Core i5
Operating System: Windows 10 Pro 64-bit Edition
Installed Memory: 8GB
Hard Drive Capacity: 256GB
Storage Type: SSD
  • Core i5
  • IEEE 802.11n
£501.76 ex VAT
£602.11 inc VAT
Packing powerful components into a petite, diamond-shaped chassis that can stand alone or snap onto the back of select Acer monitors, the Veriton N series aces your computing needs, while preserving precious space.
  • Growing with your business
    Build your desktop as you build your business with easily attachable 1 liter add-ons.
  • Breathe easy
    Designed for efficiency, the new ventilated chassis helps keep your Veriton N running cooler, longer.
  • Ideal placement
    Free up your workspace and work more effectively with the sturdy support of the VESA mount.
  • Easy internal access
    Simply slide open the chassis for quick access to the HDD, M.2 SSD, and memory without the hassle of additional tools.
Acer Veriton N4 VN4660G - compact PC - Core i5 8400 2.8 GHz - 8 GB - 256 GB
Personal computer - compact PC
Region: United Kingdom
1 x Intel Core i5 (8th Gen) 8400 / 2.8 GHz (4 GHz) (6-core)
Processor Socket
LGA1151 Socket
Processor Main Features
Intel Turbo Boost Technology 2
Cache Memory
9 MB
Cache Per Processor
9 MB
RAM
8 GB (installed) / 32 GB (max) - DDR4 SDRAM
Storage Controller
SATA
Hard Drive
1 x SSD 256 GB - M.2 2280
Optical Storage
No optical drive
Graphics Controller
Intel UHD Graphics 630
GigE, 802.11a, 802.11b/g/n, 802.11ac Wave 2, Bluetooth 5.0
OS Provided
19.2 cm x 20.4 cm x 3.32 cm
1.5 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 1 year - carry-in
Personal computer
Product Form Factor
Compact PC
Processor / Chipset
CPU
Max Turbo Speed
4 GHz
Number of Cores
6-core
CPU Qty
1
Max CPU Qty
1
CPU Socket
LGA1151 Socket
Chipset Type
Intel B360
Cache Memory
Installed Size
9 MB
Cache Per Processor
9 MB
RAM
Installed Size
8 GB / 32 GB (max)
DDR4 SDRAM
Effective Memory Speed
2666 MHz
Rated Memory Speed
2666 MHz
SO-DIMM 260-pin
Dual channel memory architecture
Configuration Features
1 x 8 GB
Hard Drive
SSD - M.2 2280
1 x 256 GB
Manufacturer
Micron
Storage Controller
1 x SATA
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Video Interfaces
HDMI, DisplayPort
Audio Output
High Definition Audio
Input Device
Mouse, keyboard
Keyboard
USB
Mouse
USB
Ethernet Controller
Realtek RTL8111EPV
Wireless LAN Supported
Wireless NIC
Intel Wireless-AC 9560
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac Wave 2, Bluetooth 5.0
Remote Management Protocol
DMI
Wake on LAN (WoL), PXE support
Slots
1 (total) / 1 (free) x PCIe x16 , 3 M.2 Card
2 x USB 2.0 , 3 x USB 3.1 Gen 1 , 1 x USB 3.1 Gen 2 , 1 x USB-C 3.1 , 1 x LAN (Gigabit Ethernet) , 1 x HDMI , 1 x DisplayPort , 1 x headphones (1 in front) , 1 x microphone (1 in front) , 1 x VGA
VESA mounting kit, 2x wireless aerials, ADP holder for VESA kit
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), chassis intrusion alarm
Security Slot Type
Kensington security slot
TUV GS, BSMI, CB, FCC, RoHS, PC 2001
Power adapter
Power Provided
90 Watt
Operating System / Software
OS Provided
ENERGY STAR Certified
19.2 cm
20.4 cm
3.32 cm
1.5 kg
Acer Veriton N4660G Core i5-8400 8GB 256GB SSD Windows 10 Pro Bundle deal on Acer Veriton N4660G Core i5-8400 8GB 256GB SSD Windows 10 Pro
£681.34
saving £2.42
£600.93
Storage Type: SSD
Processor Model: I5-8400
Type: Personal computer
Case Style: Ultra small form factor
Display: not included
Optical Storage: None
Brand: Acer
Price Range Ex VAT: 500 - 750
