Acer Veriton N4640G Core i3-4160T 4GB 500GB SFF Windows 7 Pro
Quicklinx: C9GFWS00 Mfr#: DT.VNHEK.001
  • Core i3
The Veriton 4 series is ready to meet various business needs. Powerful processors and fast memory deliver serious performance, while a premium software suite offers security and manageability to fuel business growth.
  • Breathe easy
    Designed for efficiency, the ventilated chassis helps keep your Veriton N running cooler, longer.
  • Ideal placement
    Free up your workspace and work more effectively with the sturdy support of the VESA mount.
  • Easy internal access
    Simply slide open the chassis for quick access to the HDD, M.2 SSD, and memory without the hassle of additional tools.
  • Kensington Security Slot
    The Kensington Security Slot is an anti-theft system that allows for one end of a security cable to be locked into a reinforced hole on the device while the other end is attached to a stationary object for additional device security.
  • Keep a healthy PC
    Know when components are not functioning properly and avoid system failures with the Acer System Health Indicator.
  • Strong on security
    The hardware-level Trusted Platform Module is serious security for any business that is serious about security.
Acer Veriton N4 VN4640G - tiny - Core i3 6100T 3.2 GHz - 4 GB - HDD 500 GB
Personal computer - tiny
Region: United Kingdom
Intel Core i3 (6th Gen) 6100T / 3.2 GHz (Dual-Core)
Processor Socket
LGA1151 Socket
Cache Memory
3 MB
Cache Per Processor
3 MB
RAM
4 GB (installed) / 16 GB (max) - DDR4 SDRAM
Storage Controller
SATA
Hard Drive
HDD 500 GB - SATA 6Gb/s - 5400 rpm
Optical Storage
No optical drive
Graphics Controller
Intel HD Graphics 530
GigE
OS Provided
Microsoft Windows 7 Professional 64-bit Edition / Windows 10 Pro 64-bit Edition Dual Load
19.2 cm x 20.4 cm x 3.32 cm
1.5 kg
Personal computer
Product Form Factor
Tiny
Embedded Security
Trusted Platform Module (TPM 1.2) Security Chip
Processor / Chipset
CPU
Clock Speed
3.2 GHz
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
CPU Socket
LGA1151 Socket
Chipset Type
Intel H110 Express
Cache Memory
Installed Size
3 MB
Cache Per Processor
3 MB
RAM
Installed Size
4 GB / 16 GB (max)
DDR4 SDRAM
Effective Memory Speed
2133 MHz
SO-DIMM 260-pin
Configuration Features
1 x 4 GB
Hard Drive
HDD
1 x 500 GB
Interface Type
SATA 6Gb/s
Spindle Speed
5400 rpm
Storage Controller
1 x SATA
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Video Interfaces
VGA, HDMI, DisplayPort
Input Device
Mouse, keyboard
Keyboard
USB
Mouse
USB
Slots
1 (total) / 0 (free) x CPU , SO-DIMM 260-pin , 1 PCIe x16 , 1 PCIe
4 x USB 3.0 (3 front, 1 rear) , 2 x USB 2.0 (2 rear) , 1 x microphone (1 in front) , 1 x headphones (1 in front) , 1 x headphones/microphone , 1 x LAN (Gigabit Ethernet) , 1 x VGA , 2 x DisplayPort , 1 x HDMI
VESA mounting kit
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
RoHS
Power adapter
Power Provided
65 Watt
Operating System / Software
OS Provided
19.2 cm
20.4 cm
3.32 cm
1.5 kg
