Everything you need from a standard sized desktop in a fraction of the space. Maintain productivity with powerful features that keep your business running smoothly.
Powerful performance
Heavy-duty performance for all the programs you need to work. No lag nor freezing of large spreadsheets, multiple presentations or when editing large graphics. With an advanced processor and a powerful graphics card. -
Faster file access
Smoothly and quickly view and edit large spreadsheets, presentations and video. With higher performance and lower power, DDR4 memory and the SATA SSD give accelerated access to files and the operating system. -
Ports for all occasions
Expand the functionality with a host of ports to connect almost any secondary device. The USB ports front and back, a legacy VGA port, a modern HDMI port and a Gigabit LAN Ethernet port allow it to operate in many office environments. -
Faster wireless speeds
In wireless offices it's important to have PCs capable of fast Wi-Fi access. The integrated wireless module provides slicker streaming.
- Acer Veriton Essential ES2 VES2710G - MT - Core i5 7400 3 GHz - 8 GB - 256 GB
- Personal computer - mini tower
- Localisation
- Region: United Kingdom
- Processor
- 1 x Intel Core i5 (7th Gen) 7400 / 3 GHz (3.5 GHz) (Quad-Core)
- Processor Socket
- LGA1151 Socket
- Processor Main Features
- Intel Turbo Boost Technology 2
- Cache Memory
- 6 MB
- Cache Per Processor
- 6 MB
- RAM
- 8 GB (installed) / 32 GB (max) - DDR4 SDRAM
- Storage Controller
- SATA
- Hard Drive
- 1 x SSD 256 GB
- Optical Storage
- DVD-Writer
- Graphics Controller
- Intel HD Graphics 630
- Audio Output
- 5.1 channel surround
- Networking
- GigE
- Power
- AC 120/230 V
- OS Provided
- Windows 10 Pro 64-bit Edition
- 16.5 cm x 32 cm x 34 cm
- 8 kg
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - 1 year - carry-in
- Personal computer
- Product Form Factor
- Mini tower
- Embedded Security
- Trusted Platform Module (TPM 2.0) Security Chip
- Localisation
Processor / Chipset
- CPU
- Intel Core i5 (7th Gen) 7400 / 3 GHz
- Max Turbo Speed
- 3.5 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Socket
- LGA1151 Socket
- Chipset Type
- Intel H110 Express
Cache Memory
- Installed Size
- 6 MB
- 6 MB
RAM
- Installed Size
- 8 GB / 32 GB (max)
- Technology
- DDR4 SDRAM
- Effective Memory Speed
- 2400 MHz
- Rated Memory Speed
- 2400 MHz
- Form Factor
- DIMM 288-pin
- Unbuffered, dual channel memory architecture
- Configuration Features
- 1 x 8 GB
Hard Drive
- SSD
- Capacity
- 1 x 256 GB
- Manufacturer
- Kingston
Storage Controller
- 1 x SATA
Optical Storage
- DVD-Writer - SATA
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Video Interfaces
- VGA, HDMI
Audio Output
- Sound Output Mode
- High Definition Audio
Input Device
- Mouse, keyboard
Keyboard
- Interface
- USB
Mouse
- Interface
- USB
- Ethernet Controller
- Realtek RTL8111H
- Data Link Protocol
- Remote Management Protocol
- DMI
- Wake on LAN (WoL), PXE support
- Bays
- 5.25" , 3.5"
- Slots
- 1 (total) / 1 (free) x PCIe x16
- 4 x USB 2.0 (2 front, 2 rear) , 2 x USB 3.1 Gen 1 (2 rear) , 1 x LAN (Gigabit Ethernet) , 2 x audio line-in/microphone (1 front, 1 rear) , 2 x audio line-out/headphones (1 front, 1 rear) , 1 x audio line-in , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x VGA , 1 x HDMI
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- VCCI, BSMI, GS, CB, FCC, RoHS, PC 2001, EuP
- Power supply
- Nominal Voltage
- AC 120/230 V
- Power Provided
- 220 Watt
- Efficiency
- 82%+
- Power Factor Correction
- Yes (active)
Operating System / Software
- OS Provided
- ENERGY STAR Certified
- 16.5 cm
- 32 cm
- 34 cm
- 8 kg
