Show movies on a mammoth scale in a billion colors and astonishing clarity. Make your living room your personal multiplex with Acer home series projectors, and leave behind the ordinary in entertainment for a cinematic experience that is truly awesome.
Bright and natural colors
Movies are massive at 300 inches (762 cm) and a billion colors. Action sequences are thrilling at an authentic 24p frame rate and with AcuMotion's blur control. With the superb clarity, you'll enjoy rich details, bright and natural colors, and exceptional contrast. -
Easier
Position the picture just how you want it without moving the projector itself on models with lens shift control. Others let you choose among resolutions and aspect ratios or even among sources thanks to simultaneous connectivity. When you attach an image source, it's instantly found by smart detection. -
More real
Movies gain depth and feeling with available 3D solutions that deliver stereoscopic visuals. Plus, those visuals are flicker free thanks to high refresh rates. Scenes and characters seem more real with keystone correction providing the perfect rectangular image. All models come with multiple connectors, including HDMI, DVI and VGA. -
More green
Enjoy your favorite movies again and again with no "burnout" thanks to Home Series projector bulbs, which in economy mode last long hours - that's more than two thousand films. Need an intermission? No eco-worries, as Acer EcoProjection technology reduces standby power consumption by up to 90%.
- Acer V7500 - DLP projector - 3D
- DLP projector - 1080p
- 3D Capable
- Built-in Devices
- Speaker
- Microdisplay
- DarkChip 3
- Brightness
- 2500 ANSI lumens
- Contrast Ratio
- 20000:1 (dynamic)
- Resolution
- Full HD (1920 x 1080)
- Native Aspect Ratio
- 16:9
- Colour Support
- 1.07 billion colours
- Lens Shift Direction
- Vertical
- Bulb type
- UHP 260 Watt
- Bulb life cycle
- Up to 3000 hour(s) - normal mode , Up to 7000 hour(s) - economic mode
- Video Input
- RGB, composite video, component video (PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G)
- Video Modes
- 480p, 720p, 1080i, 1080p, 480i, 576i, 576p
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V
- 325 Watt
- 37.3 cm x 22.3 cm x 10.1 cm
- 3.1 kg
- 2-year warranty
- 3D Capable
- Built-in Devices
- Speaker
Projector
- Microdisplay
- DarkChip 3
- Brightness
- 2500 ANSI lumens
- Brightness (Reduced)
- 2000 ANSI lumens
- Contrast Ratio
- 20000:1 (dynamic)
- Image Size
- 79 cm - 762 cm
- Projection Distance
- 1 m - 7.1 m
- Throw Ratio
- 1.07 - 1.45:1
- Uniformity
- 85 %
- Digital Zoom Factor
- 2x
- Resolution
- Full HD - Full HD (1920 x 1080) (native) / 1920 x 1200 (resized)
- 16:9
- Colour Support
- Max Sync Rate (V x H)
- 120 Hz x 100 kHz
- Bulb type
- UHP 260 Watt
- Bulb life cycle
- sRGB colour profile, BrilliantColor, 16:9 aspect ratio support, EcoProjection Technology, 4:3 aspect ratio support, Acer ColorSafe II Technology, ambient light sensor, ColorBoost 3D Technology
Lens
- Lens Aperture
- F/2.5-2.93
- Zoom Factor
- 1.36x
- Keystone Correction Direction
- Horizontal, vertical
- Vertical Keystone Correction
- -30 / +30
- Horizontal Keystone Correction
- -30 / +30
- Lens Shift Type
- Manual
- Vertical
Video Input
- TV System
- PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, component video, composite video, MHL
- Video Modes
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 10 Watt
- Speakers
- 1 x mixed channel
- 1 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x component video input - RCA x 3 , 1 x HDMI - 19 pin HDMI Type A , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x USB - mini-USB Type B , 1 x Mobile High-Definition Link (MHL) / HDMI - 19 pin HDMI Type A , 1 x serial RS-232 - 9 pin D-Sub (DB-9) (management) , 1 x audio line-out - mini-phone stereo 3.5 mm
- Included Accessories
- Carrying case, wireless remote control
- Power Source
- AC
- Voltage Required
- AC 120/230 V
- 325 Watt
- Power Consumption Stand by
- 0.5 Watt
- 37.3 cm
- 22.3 cm
- 10.1 cm
- 3.1 kg
- Limited warranty - 2 years - carry-in , Limited warranty - lamp - 1 year
- 0 °C
- 40 °C
- Sound Emission
- 34 dBA
- Sound Emission (Economic Mode)
- 28 dBA
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
