Product
Acer V6 Series V196L 19" 1280 x 1024 5ms VGA DVI LED Monitor
Quicklinx: 8NTFWS00 Mfr#: UM.CV6EE.017
Explore the angle that's perfect for you with this Professional series monitor, which tilts, swivels, pivots and adjusts for height to achieve the optimal position for extended viewing. Ergonomic design provides handsome style on your desk - or off: this monitor is wall mountable, giving you clear views with more room.
Focus more sharply on your tasks with the superior contrast ratios and ultra-quick response of Professional series monitor. In-Plane Switching (IPS) technology delivers consistent viewing across wide angles, faster response time for reduced eye strain, more realistic colors, and a stable view that prevents tailing when the screen is touched.
  • Adaptable
  • Convincing
  • Prepared
    Collaborating with others is faster and more productive when you have plenty of ports available. Professional series monitor allows you to connect to a wide variety of useful devices including notebooks, tablets and giant screen TVs, thanks to helpful VGA and DVI connectivity.
  • Green focus
    Professional series monitor is RoHS compliant and mercury free. In addition, you'll see power savings of up to 68% thanks to advanced Acer EcoDisplay technologies and white LED backlighting, which cut your costs and conserve the earth's resources.
Acer V196Lbmd - LED monitor - 19"
LED-backlit LCD monitor - 19"
Panel Type
TN
Aspect Ratio
5:4
Native Resolution
1280 x 1024
Pixel Pitch
0.294 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 100000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI, VGA
Speakers
Integrated
Display Position Adjustments
Tilt
40.64 cm x 20.7 cm x 40.8 cm
3.1 kg
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
GS, ISO 9241-307, TCO '06
3 years warranty
Display Type
Diagonal Size
19"
Panel Type
TN
Aspect Ratio
5:4
Native Resolution
1280 x 1024
Pixel Pitch
0.294 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
75 Hz
Horizontal Refresh Rate
80 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
Controls & Adjustments
Brightness, contrast, H/V position, colour temperature, focus
OSD Languages
English, German, French, Italian, Finnish, Russian, Spanish, Dutch
72% NTSC colour gamut
3.1 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
1 Watt
VGA , DVI (HDCP)
Mechanical
Tilt
Tilt Angle
-5/+15
Flat Panel Mount Interface
100 x 100 mm
1 x VGA cable , 1 x audio cable
MTBF
30,000 hour(s)
Power Supply
Internal
15.8 Watt
Power Consumption Sleep
0.45 Watt
Included Software
Acer eDisplay Management
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
Limited warranty - 3 years - carry-in
20 - 80%
8NTF C2G 1m DVI-D™ M/M Dual Link Digital Video Cable In Stock £7.95
8NTF C2G 2m DVI-D™ M/M Dual Link Digital Video Cable In Stock £9.31
8NTF C2G 5m DVI-D™ M/M Dual Link Digital Video Cable In Stock £16.89
8NTF C2G 2M DVI D M/F DIGITAL VIDEO EXT CBL In Stock £10.82
8NTF C2G Velocity™ DVI-D™ Male to HDMI® Female Inline Adapter In Stock £5.00
8NTF C2G Velocity™ DVI-D™ Female to HDMI® Male Inline Adapter In Stock £7.59
8NTF C2G USB to DVI Adapter Up To 2048 x 1152 In Stock £38.98
8NTF C2G 2m HDMI to DVI-D Digital Video Cable In Stock £8.65
