Acer V246HL 24" 1920x1080 5ms VGA DVI LED Monitor - Black
Quicklinx: 90XHWS00 Mfr#: UM.FV6EE.001
Everyday series monitors give you the beauty you appreciate and the value you need. They showcase captivating widescreen visuals as well as eco-conscious features, making them perfect for enjoying marvelous multimedia at home or in your office, studio or study.
Bright colors, sustainable vision
  • 24" Full HD Acer ComfyView display with Acer eColor technology
  • Earth-friendly: recycled plastic, LED backlight, Acer EcoDisplay
  • Extensive connectivity: VGA and DVI
  • 100 million: 1 contrast ratio
The Acer V246HL display features Acer eColor technology that makes every pixel clear and colorful on the non-glare 24'' screen. Together with White LED Technology, V6 series, ensures exceptional reliability and great savings as well as a better performance.
Tilt design of this display ensures the best viewing angle at daily operation. Besides, the V6 displays have thin body and grooves design on the tray of base to put your stationary on.
The Acer V246HL display delivers vibrant visuals and comfortable viewing ideal for business users.
Acer V246HL - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class F
Energy Consumption per Year
34 kWh
Power Consumption (On mode)
22.1 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Brightness
250 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI, VGA
Display Position Adjustments
Tilt
Voltage
AC 120/230 V
56.7 cm x 20.68 cm x 42.22 cm
3.9 kg
United Kingdom, Europe, EMEA
Display Type
Energy Class
Class F
34 kWh
Diagonal Size
24"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
HDCP, Acer EcoDisplay
56.7 cm x 20.68 cm x 42.22 cm - with stand
3.9 kg
VGA , DVI
Mechanical
Tilt
Tilt Angle
-5/+25
VESA Mounting Interface
100 x 100 mm
1 x VGA cable
Input Voltage
AC 120/230 V
22.1 W
22.1 kWh/1000h
Power Consumption (Typical)
20.9 Watt
Power Consumption Stand by
450 mW
Power Consumption Sleep
350 mW
On / Off Switch
No
Dimensions & Weight Details
Without stand - width: 56.7 cm - depth: 5.2 cm - height: 33.59 cm - weight: 3.5 kg
90XH C2G 2m HDMI to DVI-D Digital Video Cable In Stock £11.38
