Acer V246HL 24" 1920x1080 5ms VGA DVI HDMI LED Monitor
Quicklinx: BQRQWS00 Mfr#: UM.FV6EE.026
Diagonal Size: 24in
Max Resolution: 1920 x 1080
Response Time: 5ms
Speakers: None
Interfaces: DVI, HDMI, VGA (HD-15)
More than 50 in stock
£83.31 ex VAT
£99.97 inc VAT
Everyday series monitors give you the beauty you appreciate and the value you need. They showcase captivating widescreen visuals as well as eco-conscious features, making them perfect for enjoying marvelous multimedia at home or in your office, studio or study.
Acer V246HLbid - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class A
Energy Consumption per Year
34 kWh
Power Consumption (On mode)
23 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
5 ms (On/Off)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
56.7 cm x 20.68 cm x 42.22 cm
3.9 kg
Germany
Environmental Standards
TCO Certified Displays 8, ENERGY STAR Qualified
3-year warranty
TravelMate P614-51-50AA, P614-51TG-52A6, TMP614-51-588N; TravelMate X5 TMX514-51-560Q
Display Type
Energy Class
Class A
34 kWh
23 W
Diagonal Size
24"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (On/Off)
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Acer EcoDisplay, eColor Management, Acer Adaptive Contrast Management (ACM), High Frame Rate Control (Hi-FRC), ComfyView, Mercury free, Acer eColor technology
56.7 cm x 20.68 cm x 42.22 cm - with stand
3.9 kg
VGA , DVI , HDMI
Mechanical
Tilt
Tilt Angle
-5/+25
VESA Mounting Interface
100 x 100 mm
VESA interface support
1 x VGA cable
Germany
Power Supply
Internal
20.9 Watt
Power Consumption Stand by
450 mW
Power Consumption Sleep
350 mW
On / Off Switch
No
Dimensions & Weight Details
Without stand - width: 56.7 cm - depth: 5.2 cm - height: 33.59 cm - weight: 3.5 kg , With stand - width: 56.6 cm - depth: 20.68 cm - height: 42.22 cm - weight: 3.9 kg
TCO Certified
ENERGY STAR Certified
Limited warranty - 3 years - carry-in
Acer TravelMate P614-51-50AA, P614-51TG-52A6, TMP614-51-588N , Acer TravelMate X5 TMX514-51-560Q
Accessories (6)
BQRQ StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount In Stock £110.82
BQRQ StarTech.com Articulating Monitor Arm In Stock £103.13
BQRQ StarTech.com Dual Monitor Stand In Stock £70.24
BQRQ StarTech.com Cubicle Monitor Hanger In Stock £46.01
BQRQ StarTech.com TV/Monitor Arm - Wallmount In Stock £66.06
BQRQ StarTech.com Monitor Arm - Heavy Duty In Stock £73.69
Other bundles (4)
BQRQ C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
BQRQ C2G 0.5m Select High Speed HDMI with Ethernet In Stock £6.40
BQRQ C2G 5m Select High Speed HDMI with Ethernet In Stock £21.37
BQRQ C2G HDMI to VGA Adapter Converter Dongle - Video converter - Black In Stock £14.57
Diagonal Size: 24in
Response Time: 5ms
Speakers: None
Interfaces: DVI
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: Acer
Price Range Ex VAT: 50 - 100
