The stunning Acer V series monitor delivers vibrant visuals and comfortable viewing ideal for extended use. Its cinematic widescreen with Full HD resolution and superior contrast ratio presents detailed imagery for prolific multitasking. What's more, this display features power-saving technologies to conserve cost and resources.
Designed for Comfort
Find the perfect position for your viewing needs with this sturdy yet flexible design. -
What a View
Get the most out of your viewing experience with high-resolution colours and innovative eye-care technology. -
More Screen to See
The ZeroFrame bezel design with narrower borders offers more space for viewing. -
A View for All
Share your screen with every corner of the room as colours stay true no matter what angle you're viewing from. -
Flexible Stability
Relax at the perfect viewing angle with the adjustable tilt function and improved stand stability. -
The Beauty of Sound
Set the tone with full, vibrant audio from the on-board dual speaker sound system. -
All for 4K
Once you've sat in front of a 4K screen, you'll never settle for less. See the difference with the splendour of 4K. -
Care for Your Vision
Acer VisionCare incorporates several technologies to reduce eye strain and provide a more comfortable viewing experience. -
Settings, Your Way
Take control of customisable display settings, split-screen options and more with the easily accessible Acer Display Widget.
- Acer V227Qbi - LED monitor - Full HD (1080p) - 21.5"
- LED-backlit LCD monitor - 21.5"
- Energy Class
- Class A
- Energy Consumption per Year
- 30 kWh
- Power Consumption (On mode)
- 21 W
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 75 Hz
- Pixel Pitch
- 0.248 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 100000000:1 (dynamic)
- Response Time
- 4 ms
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72% NTSC
- Input Connectors
- HDMI, VGA
- Tilt
- Screen Coating
- Anti-reflective
- Voltage
- AC 120/230 V (50/60 Hz)
- Matte black
- 49 cm x 18.6 cm x 39.6 cm
- 3.49 kg
- Environmental Standards
- TCO Certified Displays 8, ENERGY STAR Qualified
- 3-year warranty
- Display Type
- Energy Class
- Class A
- 30 kWh
- Diagonal Size
- 21.5"
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.248 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 72% NTSC
- Response Time
- 4 ms
- Vertical Refresh Rate
- 55 - 76 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-reflective
- Backlight Technology
- LED backlight
- OSD Languages
- English, German, French, Italian, Portuguese, Polish, Finnish, Russian, Spanish, Dutch, Chinese
- ComfyView, Zero Frame, Flicker-Less technology, Blue Light Filter technology, 72% NTSC colour gamut
- Matte black
- 49 cm x 18.6 cm x 39.6 cm - with stand
- 3.49 kg
- HDMI , VGA
Mechanical
- Tilt
- Tilt Angle
- -5/+25
- VESA Mounting Interface
- 100 x 100 mm
- VESA interface support
- Cables Included
- 1 x VGA cable - 1.8 m
- MTBF
- 30,000 hour(s)
- Input Voltage
- 21 W
- Power Consumption (Typical)
- 13 Watt
- Power Consumption Stand by
- 0.33 Watt
- Power Consumption Sleep
- 0.27 Watt
- Dimensions & Weight Details
- With stand - width: 49 cm - depth: 18.6 cm - height: 39.6 cm - weight: 3.49 kg , Without stand - depth: 6.5 cm
- Shipping Weight
- 5.3 kg
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
- ENERGY STAR Version
- 7.0
- Limited warranty - 3 years - carry-in
- 0 °C
- 40 °C
- 20 - 80%
