Acer V227bip 27" 1920x1080 4ms VGA HDMI DisplayPort LED Monitor
Quicklinx: D9ZSWS00 Mfr#: UM.HV7EE.004
Diagonal Size: 27in
Max Resolution: 1920 x 1080
Response Time: 4ms
Interfaces: DisplayPort, HDMI, VGA (HD-15)
More than 50 in stock
£135.41 ex VAT
£162.49 inc VAT
The stunning Acer V series monitor delivers vibrant visuals and comfortable viewing ideal for extended use. Its cinematic widescreen with Full HD resolution and superior contrast ratio presents detailed imagery for prolific multitasking. What's more, this display features power-saving technologies to conserve cost and resources.
Acer V277bip - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class A+
Energy Consumption per Year
24 kWh
Power Consumption (On mode)
16.17 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 75 Hz
Pixel Pitch
0.311 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 100000000:1 (dynamic)
Response Time
4 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Tilt
Matte black
61.4 cm x 20.7 cm x 46.4 cm
Environmental Standards
ENERGY STAR Qualified
3-year warranty
Display Type
Energy Class
Class A+
24 kWh
16.17 W
Diagonal Size
27"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
4 ms
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
OSD Languages
English, German, French, Italian, Polish, Finnish, Russian, Spanish, Dutch, Chinese
Acer Adaptive Contrast Management (ACM), ComfyView, 100% sRGB colour gamut, Zero Frame, Flicker-Less technology
Matte black
61.4 cm x 20.7 cm x 46.4 cm - with stand
VGA , DisplayPort , HDMI
Mechanical
Tilt
Tilt Angle
-5/+25
VESA Mounting Interface
100 x 100 mm
1 x VGA cable - 1.8 m , 1 x DisplayPort cable - 1.8 m
MTBF
30,000 hour(s)
Power Consumption Stand by
0.37 Watt
Power Consumption Sleep
0.42 Watt
Power Consumption (Off Mode)
0.37 Watt
Dimensions & Weight Details
With stand - width: 61.4 cm - depth: 20.7 cm - height: 46.4 cm , Without stand - width: 61.4 cm - depth: 6.6 cm
ENERGY STAR Certified
Limited warranty - 3 years - carry-in
20 - 80%
Acer V227bip 27 Bundle deal on Acer V227bip 27" 1920x1080 4ms VGA HDMI DisplayPort LED Monitor
£234.58
Diagonal Size: 27in
Response Time: 4ms
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: Acer
Price Range Ex VAT: 100 - 150
