The stunning Acer V series monitor delivers vibrant visuals and comfortable viewing ideal for extended use. Its cinematic widescreen with Full HD resolution and superior contrast ratio presents detailed imagery for prolific multitasking. What's more, this display features power-saving technologies to conserve cost and resources.
Sustainably Designed
Our Vero monitors are designed to give you a more sustainable choice in displays. This monitor is built with 35% PCR plastics, features 100% recyclable packaging, and is TCO, ENERGY STAR, and EPEAT Silver certified. -
A Sight to Behold
Take productivity to the next level with 4K ultra-high definition resolution. Text, images, and more will be crisp and clear for a more enjoyable user experience. -
Vivid Visuals
Whether choosing photos or editing videos, the 90% DCI-P3 color coverage with up to 1.07 billion colors and HDR10 support give you more precise colors and enhanced color depth to bring out all the details of your work. -
Protecting Your Eyes
This display comes equipped Acer VisionCare eye-protecting technologies such as Acer BlueLightShield, Flickerless, Low-dimming, and ComfyView. -
Adaptive Sync
With Adaptive Sync, the monitor's framerate is synced with your graphics card, eliminating screen tearing and delivering ultra-smooth video playback. -
The Perfect Angle
Tilt and utilize a VESA mount on this monitor to always have a perfect angle to view your content.
- Acer V277bi - LED monitor - Full HD (1080p) - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class F
- Energy Consumption per Year
- 24 kWh
- Power Consumption (On mode)
- 17 W
- Adaptive-Sync Technology
- AMD FreeSync
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 75 Hz
- Brightness
- 250 cd/m²
- Response Time
- 4 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72% NTSC
- Input Connectors
- HDMI, VGA
- Tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- 61.4 cm x 20.7 cm x 46.4 cm
- 5.85 kg
- Localisation
- United Kingdom
- Environmental Standards
- TCO Certified Displays 8, ENERGY STAR Qualified
- Display Type
- Energy Class
- Class F
- 24 kWh
- Diagonal Size
- 27"
- AMD FreeSync
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 250 cd/m²
- Colour Support
- Colour Gamut
- 72% NTSC
- Response Time
- Vertical Refresh Rate
- 55 - 75 Hz
- Horizontal Refresh Rate
- 30 - 80 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- 72% NTSC colour gamut
- 61.4 cm x 20.7 cm x 46.4 cm - with stand
- 5.85 kg
- HDMI , VGA
Mechanical
- Tilt
- Tilt Angle
- -5/+25
- VESA interface support
- Localisation
- United Kingdom
- Input Voltage
- 17 W
- Power Consumption SDR (On mode)
- 26.1 kWh/1000h
- Power Consumption (Typical)
- 16.2 Watt
- Power Consumption Stand by
- 0.42 Watt
- 0.37 Watt
- Dimensions & Weight Details
- With stand - width: 61.4 cm - depth: 20.7 cm - height: 46.4 cm - weight: 5.85 kg , Without stand - width: 61.4 cm - depth: 6.6 cm - height: 36.7 cm - weight: 5 kg
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
