Acer V226WL 22" 1680x1050 5ms DVI LED Monitor
Quicklinx: 9LBPWS00 Mfr#: UM.EV6EE.008
Diagonal Size: 22in
Max Resolution: 1680 x 1050
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: DVI, VGA (HD-15)
£100.52 ex VAT
£120.62 inc VAT
Explore the angle that's perfect for you with this Professional Series monitor, which tilts, swivels, pivots and adjusts for height to achieve the optimal position for extended viewing. Its ergonomic design provides handsome style on your desk - or off: this monitor is wall mountable, giving you clear views with more room. The contrast ratio of the monitor is superior and the response is ultra-quick. In-Plane Switching (IPS) technology delivers consistent viewing across wide angles, faster response time for reduced eye strain, more realistic colors, and a stable view that prevents tailing when the screen is touched. Moreover, the monitor allows you to connect to a wide variety of useful devices including notebooks, tablets and giant screen TVs, thanks to helpful VGA, DVI, HDMI, USB and even DisplayPort connectivity options. Professional Series monitors are mercury free. In addition, you'll see power savings of up to 68% thanks to advanced Acer EcoDisplay technologies and white LED backlighting, which cut your costs and conserve the earth's resources. Acer also uses recyclable packaging to further reduce ecological impact.
  • Adaptable
    Explore the angle that's perfect for you with this Professional Series monitor, which tilts, swivels, pivots and adjusts for height to achieve the optimal position for extended viewing. Its ergonomic design provides handsome style on your desk - or off: This monitor is wall mountable, giving you clear views with more room.
  • Convincing
    Focus more sharply on your tasks with the superior contrast ratios and ultra-quick response of Professional Series monitors. In-Plane Switching (IPS) technology delivers consistent viewing across wide angles, faster response time for reduced eye strain, more realistic colors, and a stable view that prevents tailing when the screen is touched.
  • Prepared
    Collaborating with others is faster and more productive when you have plenty of ports available. Professional Series monitors allow you to connect to a wide variety of useful devices including notebooks, tablets and giant screen TVs, thanks to helpful VGA, DVI, HDMI, USB and even DisplayPort connectivity options.
  • Green focus
Acer V226WLbmd - LED monitor - 22"
LED-backlit LCD monitor - 22"
Panel Type
TN
Aspect Ratio
16:10
Native Resolution
1680 x 1050
Pixel Pitch
0.282 mm
Brightness
250 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Speakers
Internal
50.58 cm x 20.7 cm x 41.91 cm
3.52 kg
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
TUV GS, ISO 9241-307
3-year warranty
Display Type
Diagonal Size
22"
Panel Type
TN
Aspect Ratio
16:10
Native Resolution
1680 x 1050
Pixel Pitch
0.282 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
75 Hz
Horizontal Refresh Rate
80 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
HDCP
3.52 kg
Audio
Speakers - stereo - internal
Output Power / Channel
2 Watt
VGA , DVI-D (HDCP)
Mechanical
VESA Mounting Interface
100 x 100 mm
Power Supply
Internal
AC 120/230 V
17.2 Watt
Power Consumption Stand by
0.45 Watt
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
Limited warranty - 3 years - carry-in
Acer V226WL 22 Bundle deal on Acer V226WL 22" 1680x1050 5ms DVI LED Monitor
£199.69
9LBP C2G 1m DVI-D™ M/M Dual Link Digital Video Cable In Stock £7.80
9LBP C2G 2m DVI-D™ M/M Dual Link Digital Video Cable In Stock £9.11
9LBP C2G 5m DVI-D™ M/M Dual Link Digital Video Cable In Stock £16.55
9LBP C2G Velocity™ DVI-D™ Male to HDMI® Female Inline Adapter In Stock £5.00
9LBP C2G 2m HDMI to DVI-D Digital Video Cable In Stock £8.46
Diagonal Size: 22in
Response Time: 5ms
Interfaces: DVI
Interfaces: VGA (HD-15)
Brand: Acer
Price Range Ex VAT: 100 - 150
