Acer V226HQLbmd 21.5" 1920x1080 5ms VGA DVI Monitor
Quicklinx: CPG3WS00 Mfr#: UM.WV6EE.009
Everyday series monitors give you the beauty you appreciate and the value you need. They showcase captivating widescreen visuals as well as eco-conscious features, making them perfect for enjoying marvelous multimedia at home or in your office, studio or study.
Acer V226HQL - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
Energy Class
Class F
Energy Consumption per Year
32 kWh
Power Consumption (On mode)
19 W
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Brightness
250 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI, VGA
Speakers
Integrated
Voltage
AC 120/230 V
50.8 cm x 20.68 cm x 39.05 cm
3.66 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
TCO Certified Displays 8, ENERGY STAR Qualified
Display Type
Energy Class
Class F
32 kWh
Diagonal Size
21.5"
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
HDCP
3.66 kg
Audio
Speakers - integrated
VGA , DVI
Mechanical
VESA Mounting Interface
100 x 100 mm
1 x VGA cable
Input Voltage
AC 120/230 V
19 W
19 kWh/1000h
Power Consumption (Typical)
16.5 Watt
Power Consumption Stand by
450 mW
On / Off Switch
No
Dimensions & Weight Details
Without stand - weight: 3.24 kg
Sustainability Information
TCO Certified
ENERGY STAR Certified
