Acer V226HQLBbd 21.5" 1920x1080 5ms VGA DVI LED Monitor
Quicklinx: G0JKWS00 Mfr#: UM.WV6EE.B20
V6 Series monitors feature Acer eColor technology for striking visuals, and Acer ComfyView innovations that reduce glare to deliver most-comfortable viewing. These sturdy monitors also have a wide array of ports, so you can connect many types of devices and do more at once. In addition, they utilize eco-friendly features to save power and money.
  • VESA mount
    Save space and add drama to a room by putting this display on a wall. VESA mounting makes it easy.
  • Acer EcoDisplay
    This display has an environmentally friendly design that focuses on recyclability, low power consumption, and more.
  • Full HD
    1920x1080 resolution in a 16:9 aspect ratio makes movies more real and dramatic. Small details and text are clear.
  • ACM
    Whites are whiter, blacks are blacker and more detail is revealed in the shadows with Adaptive Contrast Management.
  • Acer eColor
    Easily adjust display settings to best suit whatever you're viewing - data, media, movies or photos.
Acer V226HQLBbd - V6 Series - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
Energy Class
Class F
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Brightness
200 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI, VGA
Display Position Adjustments
Tilt
Voltage
AC 120/230 V
50.8 cm x 20.68 cm x 39.05 cm
3.66 kg
Display Type
Energy Class
Class F
Diagonal Size
21.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Brightness
200 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Backlight Technology
LED backlight
50.8 cm x 20.68 cm x 39.05 cm - with stand
3.66 kg
VGA , DVI
Mechanical
Tilt
Tilt Angle
-5/+25
1 x VGA cable
Input Voltage
AC 120/230 V
19 kWh/1000h
Power Consumption (Typical)
16.5 Watt
Power Consumption Stand by
0.45 Watt
Power Consumption Sleep
0.35 Watt
Dimensions & Weight Details
With stand - width: 50.8 cm - depth: 20.68 cm - height: 39.05 cm - weight: 3.66 kg , Without stand - width: 50.8 cm - depth: 5.2 cm - height: 30.45 cm - weight: 3.24 kg
