Everyday series monitors give you the beauty you appreciate and the value you need. They showcase captivating widescreen visuals as well as eco-conscious features, making them perfect for enjoying marvelous multimedia at home or in your office, studio or study.
Designed to adapt
V6 Series monitors let you find the working angle that suits you best with a screen that tilts quickly and smoothly. The stand also has a magnetic area, great for holding paperclips and keeping your desk orderly. These monitors are also wall-mountable, giving you clear views with more room. -
Bright and clear
Focus more sharply on your tasks with the superior contrast ratios and ultra-quick response of these Full HD monitors. A range of built-in display technologies deliver consistent viewing across wide angles, faster response time for reduced eye strain, more realistic colors, and a stable view that prevents tailing when the screen is touched. -
Very connected
Collaborating with others is faster and more productive when you have plenty of ports available. V6 Series monitors allow you to connect to a wide variety of devices like notebooks and tablets, thanks to DisplayPort, VGA, DVI and HDMI ports. -
Eco focus
V6 Series monitors are RoHS compliant and mercury free. Plus, you'll see significant power savings thanks to advanced Acer EcoDisplay technologies and white LED backlighting. More than 10% of the material used in these monitors is post-consumer recycled (PCR) plastic, further reducing environmental impact.
- Acer V226HQL - LED monitor - Full HD (1080p) - 21.5"
- LED-backlit LCD monitor - 21.5"
- Energy Class
- Class F
- Energy Consumption per Year
- 32 kWh
- Power Consumption (On mode)
- 19 W
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Brightness
- 200 cd/m²
- Contrast Ratio
- 100000000:1 (dynamic)
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI, VGA
- Voltage
- AC 120/230 V
- Black
- 50.8 cm x 20.68 cm x 39.04 cm
- 3.66 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- TCO Certified Displays 8, ENERGY STAR Qualified
- MPR II
- Display Type
- Energy Class
- Class F
- 32 kWh
- Diagonal Size
- 21.5"
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 200 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 5 ms
- Horizontal Viewing Angle
- 90
- Vertical Viewing Angle
- 65
- Backlight Technology
- LED backlight
- HDCP
- Black
- 3.66 kg
- VGA , DVI
Mechanical
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable
- MPR II
- Input Voltage
- AC 120/230 V
- 19 W
- Power Consumption SDR (On mode)
- 19 kWh/1000h
- Power Consumption (Typical)
- 18.1 Watt
- Power Consumption Stand by
- 450 mW
- Power Consumption Sleep
- 350 mW
- On / Off Switch
- No
- Dimensions & Weight Details
- Without stand - weight: 3.24 kg
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
