Essential Series monitor let you find the working angle that suits you best with a screen that tilts quickly and smoothly. The stand also has a magnetic area, great for holding paperclips and keeping your desk orderly. This monitor is also wall-mountable, giving you clear views with more room.
Focus more sharply on your tasks with the superior contrast ratios and ultra-quick response of these Full HD monitors. A range of built-in display technologies deliver consistent viewing across wide angles, faster response time for reduced eye strain, more realistic colors, and a stable view that prevents tailing when the screen is touched.
Designed to adapt
Essential Series monitor let you find the working angle that suits you best with a screen that tilts quickly and smoothly. The stand also has a magnetic area, great for holding paperclips and keeping your desk orderly. This monitor is also wall-mountable, giving you clear views with more room. -
Bright and clear
Focus more sharply on your tasks with the superior contrast ratios and ultra-quick response of these Full HD monitors. A range of built-in display technologies deliver consistent viewing across wide angles, faster response time for reduced eye strain, more realistic colors, and a stable view that prevents tailing when the screen is touched. -
Very connected
Collaborating with others is faster and more productive when you have plenty of ports available. Essential Series monitors allow you to connect to a wide variety of devices like notebooks and tablets, thanks to DisplayPort, VGA, DVI and HDMI ports. -
Eco focus
Essential Series monitors are RoHS compliant and mercury free. Plus, you'll see significant power savings thanks to advanced Acer EcoDisplay technologies and white LED backlighting. More than 10% of the material used in these monitors is post-consumer recycled (PCR) plastic, further reducing environmental impact.
- Acer V226HQLAbmd - LED monitor - Full HD (1080p) - 21.5"
- LED-backlit LCD monitor - 21.5"
- Energy Class
- Class F
- Energy Consumption per Year
- 32 kWh
- Power Consumption (On mode)
- 22 W
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Brightness
- 250 cd/m²
- Contrast Ratio
- 100000000:1 (dynamic)
- Response Time
- 8 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI, VGA
- Speakers
- Integrated
- Voltage
- AC 120/230 V
- Black
- 50.8 cm x 20.68 cm x 39.04 cm
- 3.66 kg
- Environmental Standards
- TCO Certified Displays 8, ENERGY STAR Qualified
- 3-year warranty
- Display Type
- Energy Class
- Class F
- 32 kWh
- Diagonal Size
- 21.5"
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 8 ms
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- Black
- 50.8 cm x 20.68 cm x 39.04 cm - with stand
- 3.66 kg
Audio
- Speakers - integrated
- Output Power / Channel
- 1 Watt
- VGA , DVI (HDCP)
- Cables Included
- 1 x VGA cable
- Input Voltage
- AC 120/230 V
- 22 W
- Power Consumption SDR (On mode)
- 19 kWh/1000h
- Power Consumption (Typical)
- 19.5 Watt
- Power Consumption Stand by
- 350 mW
- Power Consumption Sleep
- 250 mW
- On / Off Switch
- No
- Dimensions & Weight Details
- Without stand - weight: 3.24 kg
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
- Limited warranty - 3 years - carry-in
StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount | In Stock | £143.78 |
StarTech.com Articulating Monitor Arm | In Stock | £132.69 |
StarTech.com Dual Monitor Stand | In Stock | £91.06 |
StarTech.com TV/Monitor Arm - Wallmount | In Stock | £82.52 |
StarTech.com Monitor Arm - Heavy Duty | In Stock | £93.49 |
