Acer V226HQL 21.5" 1920x1080 5ms HDMI DVI VGA LED Monitor
Quicklinx: CLZ7WS00 Mfr#: UM.WV6EE.015
Diagonal Size: 21.5in
Max Resolution: 1920 x 1080
Response Time: 5ms
Speakers: None
Interfaces: DVI, HDMI, VGA (HD-15)
More than 50 in stock
£61.74 ex VAT
£74.08 inc VAT
Everyday series monitors give you the beauty you appreciate and the value you need. They showcase captivating widescreen visuals as well as eco-conscious features, making them perfect for enjoying marvelous multimedia at home or in your office, studio or study.
Acer V226HQL - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
Energy Class
Class B
Energy Consumption per Year
32 kWh
Power Consumption (On mode)
22 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Brightness
250 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI, VGA
Display Position Adjustments
Tilt
50.8 cm x 20.68 cm x 39.05 cm
3.66 kg
Microsoft Certification
Compatible with Windows 7
TCO Displays 6.0
3-year warranty
Display Type
Energy Class
Class B
32 kWh
22 W
Diagonal Size
21.5"
Viewable Size
21.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Backlight Technology
LED backlight
Acer Adaptive Contrast Management (ACM)
50.8 cm x 20.68 cm x 39.05 cm - with stand
3.66 kg
VGA , DVI , HDMI
Mechanical
Tilt
Tilt Angle
-5/+25
1 x VGA cable
TCO Displays 6.0
AC 120/230 V
16.5 Watt
Power Consumption Stand by
0.45 Watt
Power Consumption Sleep
0.35 Watt
On / Off Switch
No
Dimensions & Weight Details
With stand - width: 50.8 cm - depth: 20.68 cm - height: 39.05 cm - weight: 3.66 kg , Without stand - width: 50.8 cm - depth: 5.2 cm - height: 30.45 cm - weight: 3.24 kg
Limited warranty - 3 years - carry-in
Acer V226HQL 21.5 Bundle deal on Acer V226HQL 21.5" 1920x1080 5ms HDMI DVI VGA LED Monitor
£160.91
CLZ7 StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount In Stock £109.46
CLZ7 StarTech.com Articulating Monitor Arm In Stock £101.86
CLZ7 StarTech.com Dual Monitor Stand In Stock £69.36
CLZ7 StarTech.com Cubicle Monitor Hanger In Stock £45.29
CLZ7 StarTech.com TV/Monitor Arm - Wallmount In Stock £50.91
CLZ7 StarTech.com Monitor Arm - Heavy Duty In Stock £72.79
Response Time: 5ms
Speakers: None
Interfaces: DVI
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: Acer
Price Range Ex VAT: 50 - 100
