Everyday series monitors give you the beauty you appreciate and the value you need. They showcase captivating widescreen visuals as well as eco-conscious features, making them perfect for enjoying marvelous multimedia at home or in your office, studio or study.
- Acer V226HQL - LED monitor - Full HD (1080p) - 21.5"
- LED-backlit LCD monitor - 21.5"
- Energy Class
- Class B
- Energy Consumption per Year
- 32 kWh
- Power Consumption (On mode)
- 22 W
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Brightness
- 250 cd/m²
- Contrast Ratio
- 100000000:1 (dynamic)
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, DVI, VGA
- Tilt
- Black
- 50.8 cm x 20.68 cm x 39.05 cm
- 3.66 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- TCO Certified Displays 8
- 3-year warranty
- Display Type
- Energy Class
- Class B
- 32 kWh
- 22 W
- Diagonal Size
- 21.5"
- Viewable Size
- 21.5"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 5 ms
- Backlight Technology
- LED backlight
- Acer Adaptive Contrast Management (ACM)
- Black
- 50.8 cm x 20.68 cm x 39.05 cm - with stand
- 3.66 kg
- VGA , DVI , HDMI
Mechanical
- Tilt
- Tilt Angle
- -5/+25
- Cables Included
- 1 x VGA cable
- Voltage Required
- AC 120/230 V
- 16.5 Watt
- Power Consumption Stand by
- 0.45 Watt
- Power Consumption Sleep
- 0.35 Watt
- On / Off Switch
- No
- Dimensions & Weight Details
- With stand - width: 50.8 cm - depth: 20.68 cm - height: 39.05 cm - weight: 3.66 kg , Without stand - width: 50.8 cm - depth: 5.2 cm - height: 30.45 cm - weight: 3.24 kg
- TCO Certified
- Limited warranty - 3 years - carry-in
StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount | In Stock | £112.29 |
StarTech.com Articulating Monitor Arm | In Stock | £103.13 |
StarTech.com Dual Monitor Stand | In Stock | £70.24 |
StarTech.com Monitor Arm - Heavy Duty | In Stock | £73.69 |
