Essential series monitors feature Acer eColor technology for striking visuals, and Acer ComfyView innovations that reduce glare to deliver most-comfortable viewing. These sturdy monitors also have a wide array of ports, so you can connect many types of devices and do more at once. In addition, they utilize eco-friendly features to save power and money.
Productivity in focus
Essential Series monitors feature Acer eColor technology for striking visuals, and Acer ComfyView innovations that reduce glare to deliver most-comfortable viewing. These sturdy monitors also have a wide array of ports, so you can connect many types of devices and do more at once. In addition, they utilize eco-friendly features to save power and money.
- Acer V196L - LED monitor - 19"
- LED-backlit LCD monitor - 19"
- Energy Class
- Class F
- Power Consumption (On mode)
- 17.5 W
- Aspect Ratio
- 5:4
- Native Resolution
- 1280 x 1024 at 75 Hz
- Brightness
- 250 cd/m²
- Contrast Ratio
- 100000000:1 (dynamic)
- Response Time
- 5 ms
- Input Connectors
- DVI, VGA
- Tilt
- Screen Coating
- Anti-glare
- Black
- 40.64 cm x 20.7 cm x 40.8 cm
- 3.1 kg
- Environmental Standards
- TCO Certified Displays 8
- FCC Part 15, RoHS, WEEE, DDC-2B/CI, Directive 2009/125/EC, EN61000-3-3:2008, EMC 2004/108/EC, LVD 2006/95/EC, EN 61000-3-2:2006+A1:2009+A2:2009 Class D, EN50581:2012, EN60950-1:2006 + A11:2009 + A1:2010 + A12:2011, EN 55024:2010, EN 55022:2006+A1:2007 Class A
- Display Type
- Energy Class
- Class F
- Diagonal Size
- 19"
- Aspect Ratio
- 5:4
- Native Resolution
- Brightness
- 250 cd/m²
- Contrast Ratio
- Response Time
- 5 ms
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- HDCP, eColor Management, Acer Adaptive Contrast Management (ACM), Acer Empowering Technology, Transition Minimised Differential Signaling (TMDS) technology
- Black
- 40.64 cm x 20.7 cm x 40.8 cm - with stand
- 3.1 kg
Audio
- Speakers
- VGA , DVI (HDCP)
Mechanical
- Tilt
- Tilt Angle
- -5/+25
- Cables Included
- 1 x VGA cable
- 17.5 W
- Power Consumption SDR (On mode)
- 17.5 kWh/1000h
- Dimensions & Weight Details
- Without stand - width: 40.64 cm - depth: 5.2 cm - height: 33.7 cm - weight: 2.7 kg , With stand - width: 40.64 cm - depth: 20.7 cm - height: 40.8 cm - weight: 3.1 kg
Sustainability Information
- TCO Certified
