Acer V196LBbmd 19" 1280x1024 VGA DVI Monitor
Quicklinx: CPFVWS00 Mfr#: UM.CV6EE.B08
Diagonal Size: 19in
Max Resolution: 1280 x 1024
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: DVI, VGA (HD-15)
£123.40 ex VAT
£148.08 inc VAT
Essential series monitors feature Acer eColor technology for striking visuals, and Acer ComfyView innovations that reduce glare to deliver most-comfortable viewing. These sturdy monitors also have a wide array of ports, so you can connect many types of devices and do more at once. In addition, they utilize eco-friendly features to save power and money.
  • Productivity in focus
    Essential Series monitors feature Acer eColor technology for striking visuals, and Acer ComfyView innovations that reduce glare to deliver most-comfortable viewing. These sturdy monitors also have a wide array of ports, so you can connect many types of devices and do more at once. In addition, they utilize eco-friendly features to save power and money.
Acer V196L - LED monitor - 19"
LED-backlit LCD monitor - 19"
Aspect Ratio
5:4
Native Resolution
1280 x 1024 at 75 Hz
Brightness
250 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
5 ms
Input Connectors
DVI, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
40.64 cm x 20.7 cm x 40.8 cm
3.1 kg
FCC Part 15, RoHS, WEEE, DDC-2B/CI, Directive 2009/125/EC, TCO Displays 6.0, EN61000-3-3:2008, EMC 2004/108/EC, LVD 2006/95/EC, EN 61000-3-2:2006+A1:2009+A2:2009 Class D, EN50581:2012, EN60950-1:2006 + A11:2009 + A1:2010 + A12:2011, EN 55024:2010, EN 55022:2006+A1:2007 Class A
Display Type
Diagonal Size
19"
Aspect Ratio
5:4
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
Response Time
5 ms
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
Anti-glare
Backlight Technology
LED backlight
HDCP, eColor Management, Acer Adaptive Contrast Management (ACM), Acer Empowering Technology, Transition Minimised Differential Signaling (TMDS) technology
40.64 cm x 20.7 cm x 40.8 cm - with stand
3.1 kg
Audio
Speakers
VGA , DVI (HDCP)
Mechanical
Tilt
Tilt Angle
-5/+25
1 x VGA cable
Dimensions & Weight Details
Without stand - width: 40.64 cm - depth: 5.2 cm - height: 33.7 cm - weight: 2.7 kg , With stand - width: 40.64 cm - depth: 20.7 cm - height: 40.8 cm - weight: 3.1 kg
Acer V196LBbmd 19 Bundle deal on Acer V196LBbmd 19" 1280x1024 VGA DVI Monitor
£223.16
Diagonal Size: 19in
Response Time: 5ms
Interfaces: DVI
Interfaces: VGA (HD-15)
Brand: Acer
Price Range Ex VAT: 100 - 150
