Acer V196LBb 19" 1280x1024 VGA Monitor
Quicklinx: CPFXWS00 Mfr#: UM.CV6EE.B01
Essential series monitors feature Acer eColor technology for striking visuals, and Acer ComfyView innovations that reduce glare to deliver most-comfortable viewing. These sturdy monitors also have a wide array of ports, so you can connect many types of devices and do more at once. In addition, they utilize eco-friendly features to save power and money.
  • Productivity in focus
    Essential Series monitors feature Acer eColor technology for striking visuals, and Acer ComfyView innovations that reduce glare to deliver most-comfortable viewing. These sturdy monitors also have a wide array of ports, so you can connect many types of devices and do more at once. In addition, they utilize eco-friendly features to save power and money.
Acer V196L - LED monitor - 19"
LED-backlit LCD monitor - 19"
Energy Class
Class F
Power Consumption (On mode)
17.5 W
Panel Type
TN
Aspect Ratio
5:4
Native Resolution
1280 x 1024 at 75 Hz
Brightness
250 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
Voltage
40.64 cm x 20.7 cm x 40.8 cm
3.1 kg
Environmental Standards
TCO Certified Displays 8
3-year warranty
Display Type
Energy Class
Class F
Diagonal Size
19"
Panel Type
TN
Aspect Ratio
5:4
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Acer Adaptive Contrast Management (ACM), ComfyView, Acer eColor technology
40.64 cm x 20.7 cm x 40.8 cm - with stand
3.1 kg
VGA
Mechanical
Tilt
Tilt Angle
-5/+25
VESA Mounting Interface
100 x 100 mm
VESA interface support
1 x VGA cable
Input Voltage
17.5 W
17.5 kWh/1000h
Power Consumption (Typical)
15.8 Watt
Power Consumption Stand by
0.45 Watt
Power Consumption (Off Mode)
0.35 Watt
Dimensions & Weight Details
Without stand - width: 40.64 cm - depth: 5.2 cm - height: 33.7 cm - weight: 2.7 kg , With stand - width: 40.64 cm - depth: 20.7 cm - height: 40.8 cm - weight: 3.1 kg
Sustainability Information
TCO Certified
Limited warranty - 3 years - carry-in
