Acer V176Lb 17" 1280x1024 5ms VGA LED Monitor
UP TO A POSSIBLE £200 CASHBACK AVAILABLE - SEE PRODUCT FOR MORE INFO
Cashback
Quicklinx: 9DHXWS00 Mfr#: UM.BV6EE.001
Essential series monitor features Acer eColor technology for striking visuals, and Acer ComfyView innovations that reduce glare for comfortable viewing. This sturdy monitor also has a wide array of ports, so you can connect many types of devices and do more at once. In addition, it utilizes eco-friendly features to save power and money.
Acer V176Lb - LED monitor - 17"
LED-backlit LCD monitor - 17"
Native Resolution
1280 x 1024
Brightness
250 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
VGA
Display Position Adjustments
Tilt
36.9 cm x 5.5 cm x 30.87 cm
2.2 kg
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
3-year warranty
Display Type
Diagonal Size
17"
Native Resolution
1280 x 1024
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
36.9 cm x 5.5 cm x 30.87 cm - without stand
2.2 kg
VGA
Mechanical
Tilt
1 x VGA cable
Power Supply
Internal
13 Watt
Power Consumption Stand by
0.35 Watt
Power Consumption Sleep
0.45 Watt
Dimensions & Weight Details
With stand - width: 36.9 cm - depth: 19.1 cm - height: 39.45 cm - weight: 2.6 kg
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
Limited warranty - 3 years - carry-in
Accessories (5)
9DHX StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount In Stock £110.82
9DHX StarTech.com Articulating Monitor Arm In Stock £103.13
9DHX StarTech.com Dual Monitor Stand In Stock £70.24
9DHX StarTech.com Cubicle Monitor Hanger In Stock £46.01
9DHX StarTech.com Monitor Arm - Heavy Duty In Stock £73.69
Other bundles (2)
9DHX C2G 2M HD15 M/M UXGA MONITOR CBL W/ FE In Stock £10.14
9DHX C2G 2m DVI-A Male to HD15 VGA Male Analogue Video Cable In Stock £11.37
