Product
Acer UT220HQL 21.5" 1920x1080 8ms HDMI VGA Touchscreen LED Monito
Quicklinx: DPQHWS00 Mfr#: UM.WW0EE.001
Diagonal Size: 21.5in
Max Resolution: 1920 x 1080
Response Time: 8ms
Speakers: None
Interfaces: HDMI, VGA (HD-15)
£190.34 ex VAT
£228.40 inc VAT
Do more than just view an image. Touch it. Control it. Interact with it using Acer's advanced touch series monitors. Multi-touch, Full HD and great digital connectivity are brought together with style to provide the ultimate touch experience. Plus, an ergonomic design lets you navigate in complete comfort.
Acer UT220HQL - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
Energy Class
Class B
Energy Consumption per Year
32 kWh
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
8 ms
Input Connectors
HDMI, VGA
51.4 cm x 4.67 cm x 38.69 cm
4.3 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
MPR II
Display Type
Energy Class
Class B
32 kWh
Diagonal Size
21.5"
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
Response Time
8 ms
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
CrystalBrite, Mobile High-Definition Link (MHL)
51.4 cm x 4.67 cm x 38.69 cm - without stand
4.3 kg
VGA , HDMI , USB
Mechanical
Tilt Angle
+10/+90
1 x VGA cable , 1 x USB cable
MPR II
19.5 Watt
Power Consumption Stand by
450 mW
Power Consumption Sleep
350 mW
Dimensions & Weight Details
With stand - width: 51.4 cm - depth: 4.67 cm - height: 38.69 cm - weight: 4.3 kg
ENERGY STAR Certified
Limited warranty - 2 years - carry-in
Acer UT220HQL 21.5 Bundle deal on Acer UT220HQL 21.5" 1920x1080 8ms HDMI VGA Touchscreen LED Monito
£285.35
Response Time: 8ms
Speakers: None
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: Acer
Price Range Ex VAT: 150 - 300
