Acer U5520B DLP 3D 3000 Lumens Projector
Quicklinx: BCW0WS00 Mfr#: MR.JL311.002
Designed to take interactivity and collaboration in the classroom to the next level, Acer U5 projectors integrates all the features that are important for schools, such as short throw projection, remote control, 3D support as well as wireless projection capability.
  • Striking visuals
    Acer U5 projectors are designed to display awesome images, so any topic comes to life in the classroom. High brightness, contrast ratio enhanced by DynamicBlack technology, and native resolution up to Full HD provide the ability to cast crystal clear, vibrant visuals with sharp edges even in bright environments. Advanced technologies devised to enhance color accuracy and fidelity make sure the image quality is unrivaled. Thanks to Acer ColorBoost 3D and Acer ColorSafe II, the U5 series projectors present nature's true colors, even when displaying 3D content or after prolonged use.
  • Short throw convenience
    With short throw capability these projectors can display large images even when placed very close to the screen. They can display sharp and accurate images. With the projector so close to the screen, there has no shadowing effect and presenters can avoid projector beams in the eyes. As a result the U5 projectors offer greater flexibility and optimal viewing comfort, making them the perfect choice for great projection in the classroom.
  • An advanced dimension in learning
    Acer U5 projectors can turn any lesson into an incredible 3D experience. Thanks to DLP 3D Ready technology, simply pair the projector with a PC or an audio or video for an amazing 3D experience. If you are after an immersive 3D cinematic experience, just connect a Blu-ray disc player via HDMI and enjoy the show. This solution unlocks endless possibilities for engaging learning, from exploring the universe to human anatomy, from discovering geometry to touring famous archaeological sites.
  • Perfect picture
    Acer U5 projectors are designed to simplify users life. Any horizontal or vertical image distortion that might be caused by improper placement of the projector is easily fixed with the H/V keystone correction. In addition, this correction enables users to adjust distortions from any corner. As a result, the projected image is perfectly rectangular no matter where the projector is placed, offering greater flexibility.
Acer U5520B - DLP projector - ultra short-throw - 3D
DLP projector - 1080p
3D Capable
Brightness
3000 lumens
Contrast Ratio
10000:1 (dynamic)
Resolution
Full HD (1920 x 1080)
Native Aspect Ratio
16:9
Colour Support
1.07 billion colours
Lens
Ultra short-throw fixed lens
Bulb type
P-VIP 280 Watt
Bulb life cycle
Up to 3000 hour(s) - normal mode , Up to 7000 hour(s) - economic mode
Video Input
RGB, S-Video, composite video (PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G)
Video Modes
480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Speakers
Speaker(s) - integrated
AC 120/230 V
351 Watt
33.9 cm x 32.3 cm x 23.7 cm
5.5 kg
3-year warranty
3D Capable
Projector
Brightness
3000 lumens
Brightness (Reduced)
2400 lumens
Contrast Ratio
10000:1 (dynamic)
Image Size
178 cm - 305 cm
Projection Distance
0.21 m - 0.61 m
Throw Ratio
0.36:1
Digital Zoom Factor
2x
Resolution
Full HD - Full HD (1920 x 1080) (native) / 1920 x 1200 (resized)
Native Aspect Ratio
16:9
Colour Support
Max Sync Rate (V x H)
120 Hz x 100 kHz
Bulb type
P-VIP 280 Watt
Bulb life cycle
Lens
Focus Type
Manual
Lens Aperture
F/2.53
Keystone Correction Direction
Horizontal, vertical
Vertical Keystone Correction
-15 / +15
Horizontal Keystone Correction
-15 / +15
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video, MHL
Video Modes
Speakers
Integrated
Sound Output Mode
Stereo
Output Power / Channel
10 Watt
Speakers
2 x right / left channel
2 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x USB - 4 pin USB Type A , 1 x Mobile High-Definition Link (MHL) / HDMI - 19 pin HDMI Type A , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x USB - mini-USB Type B , 1 x microphone - mini-phone 3.5 mm , 1 x serial RS-232 - 9 pin D-Sub (DB-9) (management) , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x S-video input - 4 pin mini-DIN , 1 x audio line-in - RCA x 2 , 1 x network - RJ-45
Wireless remote control
1 x VGA cable
Power Source
AC
AC 120/230 V
351 Watt
33.9 cm
32.3 cm
23.7 cm
5.5 kg
Limited warranty - 3 years - carry-in , Limited warranty - lamp - 1 year
Sound Emission
35 dBA
29 dBA
BCW0 C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
