Designed to take interactivity and collaboration in the classroom to the next level, Acer U5 projectors integrates all the features that are important for schools, such as short throw projection, remote control, 3D support as well as wireless projection capability.
Striking visuals
Acer U5 projectors are designed to display awesome images, so any topic comes to life in the classroom. High brightness, contrast ratio enhanced by DynamicBlack technology, and native resolution up to Full HD provide the ability to cast crystal clear, vibrant visuals with sharp edges even in bright environments. Advanced technologies devised to enhance color accuracy and fidelity make sure the image quality is unrivaled. Thanks to Acer ColorBoost 3D and Acer ColorSafe II, the U5 series projectors present nature's true colors, even when displaying 3D content or after prolonged use. -
Short throw convenience
With short throw capability these projectors can display large images even when placed very close to the screen. They can display sharp and accurate images. With the projector so close to the screen, there has no shadowing effect and presenters can avoid projector beams in the eyes. As a result the U5 projectors offer greater flexibility and optimal viewing comfort, making them the perfect choice for great projection in the classroom. -
An advanced dimension in learning
Acer U5 projectors can turn any lesson into an incredible 3D experience. Thanks to DLP 3D Ready technology, simply pair the projector with a PC or an audio or video for an amazing 3D experience. If you are after an immersive 3D cinematic experience, just connect a Blu-ray disc player via HDMI and enjoy the show. This solution unlocks endless possibilities for engaging learning, from exploring the universe to human anatomy, from discovering geometry to touring famous archaeological sites. -
Perfect picture
Acer U5 projectors are designed to simplify users life. Any horizontal or vertical image distortion that might be caused by improper placement of the projector is easily fixed with the H/V keystone correction. In addition, this correction enables users to adjust distortions from any corner. As a result, the projected image is perfectly rectangular no matter where the projector is placed, offering greater flexibility.
- Acer U5520B - DLP projector - ultra short-throw - 3D
- DLP projector - 1080p
- 3D Capable
- Brightness
- 3000 lumens
- Contrast Ratio
- 10000:1 (dynamic)
- Resolution
- Full HD (1920 x 1080)
- Native Aspect Ratio
- 16:9
- Colour Support
- 1.07 billion colours
- Lens
- Ultra short-throw fixed lens
- Bulb type
- P-VIP 280 Watt
- Bulb life cycle
- Up to 3000 hour(s) - normal mode , Up to 7000 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video (PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G)
- Video Modes
- 480p, 720p, 1080i, 1080p, 480i, 576i, 576p
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V
- 351 Watt
- 33.9 cm x 32.3 cm x 23.7 cm
- 5.5 kg
- 3-year warranty
- 3D Capable
Projector
- Brightness
- 3000 lumens
- Brightness (Reduced)
- 2400 lumens
- Contrast Ratio
- 10000:1 (dynamic)
- Image Size
- 178 cm - 305 cm
- Projection Distance
- 0.21 m - 0.61 m
- Throw Ratio
- 0.36:1
- Digital Zoom Factor
- 2x
- Resolution
- Full HD - Full HD (1920 x 1080) (native) / 1920 x 1200 (resized)
- 16:9
- Colour Support
- Max Sync Rate (V x H)
- 120 Hz x 100 kHz
- Bulb type
- P-VIP 280 Watt
- Bulb life cycle
Lens
- Focus Type
- Manual
- Lens Aperture
- F/2.53
- Keystone Correction Direction
- Horizontal, vertical
- Vertical Keystone Correction
- -15 / +15
- Horizontal Keystone Correction
- -15 / +15
Video Input
- TV System
- PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video, S-Video, MHL
- Video Modes
Speakers
- Integrated
- Sound Output Mode
- Stereo
- Output Power / Channel
- 10 Watt
- Speakers
- 2 x right / left channel
- 2 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x USB - 4 pin USB Type A , 1 x Mobile High-Definition Link (MHL) / HDMI - 19 pin HDMI Type A , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x USB - mini-USB Type B , 1 x microphone - mini-phone 3.5 mm , 1 x serial RS-232 - 9 pin D-Sub (DB-9) (management) , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x S-video input - 4 pin mini-DIN , 1 x audio line-in - RCA x 2 , 1 x network - RJ-45
- Included Accessories
- Wireless remote control
- Cables Included
- 1 x VGA cable
- Power Source
- AC
- Voltage Required
- AC 120/230 V
- 351 Watt
- 33.9 cm
- 32.3 cm
- 23.7 cm
- 5.5 kg
- Limited warranty - 3 years - carry-in , Limited warranty - lamp - 1 year
- 0 °C
- 40 °C
- Sound Emission
- 35 dBA
- Sound Emission (Economic Mode)
- 29 dBA
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
C2G HDMI to VGA Adapter Converter Dongle - Video converter - Black | In Stock | £14.57 |
