Acer U5320W DLP WXGA 3D 3000 Lumens Projector
Quicklinx: BCW1WS00 Mfr#: MR.JL111.002
Brightness: 3000ANSI lumens
Portability: Non-portable
£825.46 ex VAT
£990.55 inc VAT
The Acer U5320W is an ultra-short throw projector that can be placed as close as 23cm (9.1-inches) from the projection surface, and the ability to can project up to 100-inch images at a distance of 50cm (19.7-inches), providing greater space flexibility. It also eliminates shadowing and enhances viewing comfort, a significant benefit for classrooms. The U5320W's WXGA resolution and 3,000 lumens brightness creates crystal-clear and vibrant images, while its 2x10W speakers provide powerful sound. When paired with an optional Acer SmartPen II, the U5320W is ideal for classroom settings, allowing on-screen writing from up to a 32-foot distance for up to two users, and working as a remote control to encourage interactive learning.
Acer U5320W - DLP projector - ultra short-throw - 3D - LAN
DLP projector - 720p
3D Capable
Built-in Devices
Stereo speakers
Microdisplay
DarkChip 3
Brightness
3000 ANSI lumens
Contrast Ratio
13000:1 (dynamic)
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Colour Support
1.07 billion colours
Lens
Ultra short-throw fixed lens
Bulb type
UHP 240 Watt
Bulb life cycle
Up to 3000 hour(s) - normal mode , Up to 6000 hour(s) - economic mode
Video Input
S-Video, composite video, component video (PAL, PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G), LAN
Video Modes
480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Speakers
Speaker(s) - integrated
299 Watt
5.5 kg
3-year warranty
3D Capable
Built-in Devices
Stereo speakers
Projector
Microdisplay
DarkChip 3
Brightness
3000 ANSI lumens
Brightness (Reduced)
2400 ANSI lumens
Contrast Ratio
13000:1 (dynamic)
Image Size
177 cm - 305 cm
Projection Distance
0.22 m - 0.63 m
Throw Ratio
0.37:1
Digital Zoom Factor
2x
Resolution
WXGA - WXGA (1280 x 800) (native) / 1920 x 1200 (resized)
Native Aspect Ratio
16:10
Colour Support
Max Sync Rate (V x H)
120 Hz x 100 kHz
Bulb type
UHP 240 Watt
Bulb life cycle
Ultra Short Throw Technology
Lens
Focus Type
Manual
Lens Aperture
F/2.53
Keystone Correction Direction
Horizontal, vertical
Vertical Keystone Correction
-15 / +15
Horizontal Keystone Correction
-15 / +15
Video Input
TV System
Analogue video Signal
Video Interfaces
HDMI, composite video, S-Video
Video Modes
LAN and Wireless Image Transferring Protocols
Wired LAN
Speakers
Integrated
Sound Output Mode
Stereo
Output Power / Channel
10 Watt
Speakers
2 x right / left channel
1 x USB - 4 pin mini-USB Type B , 2 x Mobile High-Definition Link (MHL) / HDMI - 19 pin HDMI Type A , 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 1 x network - RJ-45 (management) , 2 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 2 x audio line-in , 1 x microphone , 1 x audio line-out - RCA x 2 , 1 x VGA output , 1 x audio line-out , 1 x USB - 4 pin USB Type A , 1 x serial RS-232
Wall mounting kit
1 x VGA cable
Power Source
AC
Nominal Voltage
299 Watt
Power Consumption Stand by
0.5 Watt
5.5 kg
Limited warranty - 3 years , Limited warranty - lamp - 1 year
Sound Emission
33 dBA
27 dBA
Brand: Acer
Price Range Ex VAT: 750 - 1000
