Acer U5220 DLP XGA 3D 3000 Lumens Projector
Quicklinx: BCW3WS00 Mfr#: MR.JL211.002
Ultra Short-throw Series projectors portray clear, large images even when positioned very close to the projection screen. This makes them ideal for use in education and business environments, as well as in small rooms.
Main Features
  • DLP technology.
  • Enables projecting 3D content via DLP Link Technology: Blu-Ray 3D supported.
  • One-touch "3D" button on remote control allows quick and easy access to the 3D functions.
  • Acer ColorBoost technology delivers vivid, life-like images.
  • High brightness and contrast ratio.
  • Versatile display modes enable optimum performance in any situation.
  • Lower power consumption and economy (ECO) mode extends lamp life.
  • Dynamic black / ExtremeEco functions help decrease lamp power consumption and further extend lamp life.
  • Acer EcoProjection Technology delivers Intelligent power management approach and physical efficiency improvement.
  • Manual focus/zoom projection lens.
  • 2X digital zoom and pan move function.
Acer U5220 - DLP projector - ultra short-throw - 3D
DLP projector
3D Capable
Yes (3D glasses sold separately)
Brightness
3000 lumens
Contrast Ratio
13000:1 (dynamic)
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Colour Support
1.07 billion colours
Lens
Ultra short-throw fixed lens
Bulb type
UHP 240 Watt
Bulb life cycle
Up to 3000 hour(s) - normal mode , Up to 6000 hour(s) - economic mode
Video Input
S-Video, composite video (PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G)
Video Modes
480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Speakers
Speaker(s) - integrated
AC 120/230 V
299 Watt
33.9 cm x 32.3 cm x 23.7 cm
5.5 kg
3-year warranty
DLP projector
3D Capable
Projector
Brightness
3000 lumens
Brightness (Reduced)
2400 lumens
Contrast Ratio
13000:1 (dynamic)
Image Size
152 cm - 305 cm
Projection Distance
0.23 m - 0.8 m
Throw Ratio
0.47:1
Digital Zoom Factor
2x
Resolution
XGA - XGA (1024 x 768) (native) / 1920 x 1200 (resized)
Native Aspect Ratio
4:3
Colour Support
Max Sync Rate (V x H)
120 Hz x 100 kHz
Bulb type
UHP 240 Watt
Bulb life cycle
BrilliantColor, Instant Pack Technology, DLP 3D Ready, SmartFormat Technology, 16:9 aspect ratio support, EcoProjection Technology, 24p True Cinema, Acer ColorSafe II Technology, ColorBoost 3D Technology
Lens
Lens Aperture
F/2.53
Keystone Correction Direction
Horizontal, vertical
Vertical Keystone Correction
-15 / +15
Horizontal Keystone Correction
-15 / +15
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video, MHL
Video Modes
Speakers
Integrated
Sound Output Mode
Stereo
Output Power / Channel
10 Watt
Speakers
2 x right / left channel
1 x USB - 4 pin mini-USB Type B , 2 x Mobile High-Definition Link (MHL) / HDMI , 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 1 x network - RJ-45 (management) , 2 x audio line-in - mini-phone 3.5 mm , 1 x microphone input - mini-phone 3.5 mm , 1 x audio line-in - RCA x 2 , 1 x USB - 4 pin USB Type A , 1 x serial RS-232 , 2 x component video / RGB input - 15 pin HD D-Sub (HD-15)
Wireless remote control
1 x VGA cable
Power Source
AC
AC 120/230 V
299 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
33.9 cm
32.3 cm
23.7 cm
5.5 kg
Limited warranty - 3 years - carry-in , Limited warranty - lamp - 1 year
Sound Emission
33 dBA
27 dBA
BCW3 C2G HDMI to VGA Adapter Converter Dongle - Video converter - Black In Stock £14.57
