Acer TravelMate P658-G3 Core i5-7200U 8GB 256GB 15.6" SSD Windows 10 Pro
Quicklinx: F1MPWS00 Mfr#: NX.VGJEK.001
Display Size: 15.6in
Processor Model: I5-7200U
Operating System: Windows 10 Pro 64-bit Edition
Installed Memory: 8GB
Hard Drive Capacity: 256GB
  • Core i5
  • IEEE 802.11n
£640.47 ex VAT
£768.56 inc VAT
A powerful platform and long battery life deliver a computer, that keeps up with you and lasts the working day. Innovative use of materials means that the TravelMate P6 is light and durable - ideal for on-the-go people. An ergonomic backlit keyboard with ample key travel means, that you can type accurately, even in low-light environments.
  • Advanced productivity
  • Built to last
    Innovative use of materials means, that the TravelMate P6 is light and durable - ideal for on-the-go people.
  • Type in comfort
Acer TravelMate P658-G3-M-55TB - 15.6" - Core i5 7200U - 8 GB RAM - 256 GB SSD - UK
Notebook
Operating System
Win 10 Pro 64-bit
Intel Core i5 (7th Gen) 7200U / 2.5 GHz (3.1 GHz) / 3 MB Cache
8 GB DDR4 (provided memory is soldered)
Storage
256 GB SSD
Optical Drive
No optical drive
Display
15.6" LED backlight 1366 x 768 / HD
Graphics
Intel HD Graphics 620
Keyboard
Keyboard Backlight
Numeric Keypad
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet
3-cell
Dockable
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader
38.1 cm x 25.45 cm x 2.24 cm
2.3 kg
Region: United Kingdom
Environmental Standards
ENERGY STAR Qualified
Notebook
Operating System
Processor / Chipset
CPU
Max Turbo Speed
3.1 GHz
Number of Cores
Dual-Core
Cache
3 MB
64-bit Computing
Intel Turbo Boost Technology 2.0
RAM
8 GB (provided memory is soldered)
Max RAM Supported
24 GB
DDR4 SDRAM
SO-DIMM 260-pin
Slots Qty
1
Empty Slots
1
Storage
Main Storage
256 GB SSD - (M.2 2280) - Micron
Display
15.6" - TN
LCD Backlight Technology
LED backlight
Resolution
1366 x 768 (HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
220 cd/m²
Anti-glare, ComfyView, 8 ms response rate
Audio & Video
Graphics Processor
Memory Allocation Technology
Shared Video Memory (UMA)
Camera
Yes - HD
Camera Features
HDR (High Dynamic Range)
Sound
Stereo speakers, two microphones
Audio Features
Acer TrueHarmony technology
Input
Keyboard, touchpad
Keyboard Backlight
Keyboard Layout
Numeric Keypad
Multi-gesture touch pad, Acer FineTip keyboard
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 7265 - M.2 Card
Network Interface
Gigabit Ethernet
Ethernet Controller
Intel I219-LM
Intel Wireless Display (WiDi)
3-cell lithium polymer
4850 mAh
AC Adapter
Input
Output
65 Watt, 19 V
Connections & Expansion
2 x USB 3.0 , HDMI , LAN , VGA , Dock , Headphone/microphone combo jack , USB-C 3.1 Gen 2/Thunderbolt 3/DisplayPort , USB 3.0 (with power off charging)
Memory Card Reader
Yes (SD Card)
Case Material
Polycarbonate, glass-fibre
Dockable
Security
Disc Anti-Shock Protection System (DASP
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
GS
Localization
2.3 kg
49.8 cm x 6.5 cm x 31 cm / 3.09 kg
ENERGY STAR Certified
Software applications
Acer TravelMate P658-G3 Core i5-7200U 8GB 256GB 15.6 Bundle deal on Acer TravelMate P658-G3 Core i5-7200U 8GB 256GB 15.6" SSD Windows 10 Pro
£820.05
saving £2.42
£739.64
Optical Storage: None
Graphics: Intel HD Graphics 620
Hard Drive Type: SSD
Type: Laptop
Brand: Acer
Price Range Ex VAT: 500 - 750
