Acer TravelMate P259-M i5-7200U 4GB 128GB 15.6" Win 10 Pro
Quicklinx: D6JPWS00 Mfr#: NX.VEPEK.008
Display Size: 15.6in
Processor Model: I5-7200U
Operating System: Windows 10 Pro 64-bit Edition
Installed Memory: 4GB, 4GB
Hard Drive Capacity: 128GB
  • Core i5
  • IEEE 802.11n
£422.33 ex VAT
£506.79 inc VAT
The TravelMate P2 series packs powerful processors to efficiently drive you through your work day. The notebook can extend their monitor output to a second, bigger display, so you get two screens for viewing more documents and working more effectively. Crunch numbers faster with the independent numeric keypad.
  • Smart performer
  • Efficient worker
  • Reliable and eco-friendly
    Stringent testing has prepared these notebooks to withstand rigorous use. Peace of mind is yours with the automatic file backup of Acer backup manager, and with Acer recovery management, which recovers unsaved work. This notebook has ENERGY STAR 5.0 certification and complies with other "green" directives. In addition, their easy-to-disassemble design makes them easier to be recycled.
Acer TravelMate P259-G2-M-50YF - 15.6" - Core i5 7200U - 4 GB RAM - 128 GB SSD - UK
Notebook
Operating System
Win 10 Pro 64-bit
Intel Core i5 (7th Gen) 7200U / 2.5 GHz (3.1 GHz) / 3 MB Cache
4 GB DDR4 (1 x 4 GB)
Storage
128 GB SSD
Optical Drive
DVD-Writer
Display
15.6" LED backlight 1366 x 768 / HD
Graphics
Intel HD Graphics 620
Keyboard
Numeric Keypad
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet
4-cell
38.16 cm x 25.9 cm x 3.02 cm
2.4 kg
Region: United Kingdom
Environmental Standards
ENERGY STAR Qualified
Notebook
Operating System
Processor / Chipset
CPU
Max Turbo Speed
3.1 GHz
Number of Cores
Dual-Core
Cache
3 MB
64-bit Computing
Intel Turbo Boost Technology 2.0
RAM
4 GB (1 x 4 GB)
Max RAM Supported
32 GB
DDR4 SDRAM
Speed
2133 MHz
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
128 GB SSD - (M.2 2280)
Optical Drive
DVD-Writer - tray
Display
15.6"
LCD Backlight Technology
LED backlight
Resolution
1366 x 768 (HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
220 cd/m²
Anti-glare, ComfyView
Audio & Video
Graphics Processor
Memory Allocation Technology
Shared Video Memory (UMA)
Camera
Yes - HD
Sound
Stereo speakers, microphone
Audio Features
Acer TrueHarmony technology
Input
Keyboard, touchpad
Keyboard Layout
Numeric Keypad
Multi-gesture touch pad, Acer FineTip keyboard
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 7265 - M.2 Card
Network Interface
Gigabit Ethernet
4-cell Lithium Ion
41.8 Wh
AC Adapter
Input
Output
45 Watt, 19 V
Connections & Expansion
USB 2.0 , HDMI , VGA , LAN , USB 3.0 , USB-C Gen 1 , Headphone/microphone combo jack , USB 3.0 (with power off charging)
Memory Card Reader
Yes (SD Card)
Wake on LAN
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
Localization
2.4 kg
ENERGY STAR Certified
Software applications
Acer TravelMate P259-M i5-7200U 4GB 128GB 15.6 Bundle deal on Acer TravelMate P259-M i5-7200U 4GB 128GB 15.6" Win 10 Pro
£604.49
saving £8.33
£521.50
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: D6JP 040760
Condition: Customer return - item has been repaired under warranty by the manufacturer. Please Note: This is the laptop only. Charger is not included in the box.
This part of the stock item is not present or functional  This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  £270.74
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Optical Storage: DVD-Writer
Graphics: Intel HD Graphics 620
Hard Drive Type: SSD
Brand: Acer
Stock Status: Used Stock
Price Range Ex VAT: 300 - 500
