Acer TravelMate B118-G2-RN N5000 4GB 64GB eMMC 11.6"  Win 10 Pro
Quicklinx: F1LYWS00 Mfr#: NX.VHTEK.002
Display Size: 11.6in
Processor Model: N5000
Operating System: Windows 10 Pro in S Mode 64-bit Edition
Installed Memory: 4GB, 4GB
Hard Drive Capacity: 64GB
  • Pentium
  • IEEE 802.11n
More than 50 in stock
£252.98 ex VAT
£303.57 inc VAT
Classroom learning involves a diverse array of subjects, learning environments and teaching methods; therefore the TravelMate Spin B1 convertible notebook is an ideal fit for the wide-ranging needs of students and teachers alike. The 11.6-inch convertible notebook is perfectly sized for easy portability, features four usage modes and a robust design made for day-to-day use in the classroom. In addition, with a long battery life, students can power through a full day of school and beyond.
  • Built tough to withstand knocks, drops and spills
    The TravelMate Spin B1 was designed with durability features to ensure maximum uptime and help reduce maintenance. They include a shock-absorbent middle rubber frame that can handle the rough-and-tumble of the classroom and a pressure-resistant screen. It also sports a spill-resistant keyboard that provides protection against spills of up to 330 ml (11 fluid ounces) of water. The unique gutter system under the keyboard and touchpad drains water so that it's routed away from internal components and out the bottom of the chassis. The notebook also has a Kensington lock, so that it can be secured to a wireless cart or lab.
  • Long battery life and great performance
    The TravelMate Spin B1 sports long battery life, allowing students to learn without interruption, inside and outside the classroom, with power to spare for homework. Powered by an efficient processor, the TravelMate Spin B1 offers solid everyday performance. A chiclet keyboard provides excellent tactile feedback for accurate touch-typing, and a Precision Touchpad promotes comfortable and responsive navigation.
  • Students stay connected
    Students can stay connected to their school network with fast dual-band 2x2 MIMO 802.11ac wireless connectivity. The device connects easily to peripherals via Bluetooth, one USB 3.0 port, one USB 2.0 port and one HDMI port. Students can plug in their headphones with the 3.5 mm head phone jack, while files can be easily shared with the built-in SD card reader.
Acer TravelMate Spin B1 TMB118-G2-RN-P15N - 11.6" - Pentium N5000 - 4 GB RAM - 64 GB eMMC - QWERTY UK
Notebook - flip design
Operating System
Intel Pentium N5000 / 1.1 GHz (2.7 GHz) / 4 MB Cache
4 GB DDR4 (provided memory is soldered)
Storage
64 GB - eMMC
Optical Drive
No optical drive
Display
11.6" LED backlight touchscreen 1920 x 1080 / Full HD
Graphics
Intel UHD Graphics 605
Keyboard
QWERTY UK
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet
4-cell - up to 13 hours
29.1 cm x 21.1 cm x 2.33 cm
1.53 kg
Region: United Kingdom
Limited warranty - 1 year - carry-in , Traveller warranty - 1 year
Operating System
Processor / Chipset
CPU
Max Turbo Speed
2.7 GHz
Number of Cores
Quad-Core
Cache
4 MB
64-bit Computing
Intel Burst Technology
RAM
4 GB (provided memory is soldered)
DDR4 SDRAM
Storage
Main Storage
64 GB SSD - (eMMC) - SanDisk
Display
11.6" - IPS
LCD Backlight Technology
LED backlight
Touchscreen
Yes (multi-touch)
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
300 cd/m²
Ultra Slim Design, glare, CineCrystal, 25 ms response rate
Audio & Video
Graphics Processor
Memory Allocation Technology
Shared Video Memory (UMA)
Camera
Yes - HD
Sound
Stereo speakers, two microphones
High Definition Audio
Input
Keyboard, touchpad
Keyboard Layout
QWERTY UK
Precision touchpad
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 7265 - M.2 Card
Network Interface
Gigabit Ethernet
Intel Wireless Display (WiDi), Wake-on-LAN (WOL)
4-cell Lithium Ion
3220 mAh
Run Time
Up to 13 hours
AC Adapter
Input
Output
45 Watt, 19 V
Connections & Expansion
USB 2.0 , USB 3.0 , HDMI , Headphone/microphone combo jack , LAN
Memory Card Reader
Yes (SD Card)
Spill resistant keyboard, MIL-STD-810G tested
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter, stylus holder, Acer Active Pen
Localization
1.53 kg
Software applications
Acer TravelMate B118-G2-RN N5000 4GB 64GB eMMC 11.6 Bundle deal on Acer TravelMate B118-G2-RN N5000 4GB 64GB eMMC 11.6" Win 10 Pro
£438.20
saving £8.33
£352.15
Optical Storage: None
Graphics: Intel UHD Graphics 605
Hard Drive Type: SSD
Brand: Acer
Price Range Ex VAT: 150 - 300
