The 11.6-inch convertible notebook is perfectly sized for easy portability, features four usage modes and a robust design made for day-to-day use in the classroom. In addition, with a long battery life, students can power through a full day of school and beyond.
Versatility of convertibles, now in the classroom
Classroom learning involves a diverse array of subjects, learning environments and teaching methods; therefore the TravelMate Spin B1 convertible notebook is an ideal fit for the wide-ranging needs of students and teachers alike. It features four versatile modes that facilitate all aspects of classroom learning, including Stand and Tent modes for group projects and sharing, Tablet mode for learning on the move in labs or during field trips, and Laptop mode for everything else. -
Built tough to withstand knocks, drops and spills
The TravelMate Spin B1 was designed with durability features to ensure maximum uptime and help reduce maintenance. They include a shock-absorbent middle rubber frame that can handle the rough-and-tumble of the classroom, while a pressure-resistant screen with increased strength can withstand frontal impact of up to 60Kgf. It also sports a spill-resistant keyboard that provides protection against spills of up to 330ml (11 fluid ounces) of water. The unique gutter system under the keyboard and touchpad drains water so that it's routed away from internal components and out the bottom of the chassis. -
Long battery life and great performance
The TravelMate Spin B1 sports up to 13 hours of battery life, allowing students to learn without interruption, inside and outside the classroom, with power to spare for homework. The TravelMate Spin B1 offers solid everyday performance. A chiclet keyboard provides excellent tactile feedback for accurate touch-typing, and a Precision Touchpad promotes comfortable and responsive navigation. -
Students stay connected
Students can stay connected to their school network with fast dual-band 2x2 MIMO 802.11ac wireless connectivity. The device connects easily to peripherals via Bluetooth 4.0, one USB 3.0 port, one USB 2.0 port and one HDMI port. Students can plug in their headphones with the 3.5mm head phone jack, while files can be easily shared with the built-in SD card reader.
- Acer TravelMate Spin B1 TMB118-RN-C0KG - 11.6" - Intel Celeron - N3450 - 2 GB RAM - 32 GB eMMC - UK
- Product Type
- Notebook - flip design
- Operating System
- Windows 10 in S mode 64-bit
- Processor
- Intel Celeron N3450 / 1.1 GHz, up to 2.2 GHz / 2 MB Cache
- Memory
- 2 GB DDR3L (provided memory is soldered)
- Storage
- 32 GB eMMC
- Display
- 11.6" LED backlight touchscreen 1920 x 1080 / Full HD
- Graphics
- Intel HD Graphics 500
- Input Device
- Digitizer, digital pen
- Keyboard
- UK
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet
- Battery
- 4-cell - up to 13 hours
- G-sensor
- Security
- Trusted Platform Module (TPM) Security Chip
- Black
- 29.1 cm x 21.1 cm x 2.335 cm
- 1.53 kg
- Localisation
- Region: United Kingdom
- Environmental Standards
- ENERGY STAR Qualified
- Product Type
- Operating System
- Windows 10 in S mode 64-bit Edition
Processor / Chipset
- CPU
- Max Turbo Speed
- 2.2 GHz
- Number of Cores
- Quad-Core
- Cache
- 2 MB
- 64-bit Computing
- Intel Burst Technology
- RAM
- 2 GB (provided memory is soldered)
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz
Storage
- Main Storage
- 32 GB eMMC
Display
- 11.6" - IPS
- LCD Backlight Technology
- LED backlight
- Touchscreen
- Yes (10-point multi-touch)
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 300 cd/m²
- Ultra Slim Design, glare, Mercury free, Wide Viewing Angle
Audio & Video
- Graphics Processor
- Memory Allocation Technology
- Shared Video Memory (UMA)
- Camera
- Yes - 1280 x 720
- Video Resolutions
- 720p
- Sound
- Stereo speakers, two microphones
Input
- Keyboard, digitizer, touchpad, digital pen
- Keyboard Layout
- UK
- Multi-gesture touch pad, spill-resistant, Acer FineTip keyboard, precision touchpad
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 7265 - M.2 Card
- Network Interface
- Gigabit Ethernet
- Technology
- 4-cell lithium polymer
- Capacity
- 48 Wh
- Run Time
- Up to 13 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 19 V
Connections & Expansion
- Interfaces Details
- USB 2.0 , USB 3.0 , HDMI , Headphone/microphone combo jack , LAN
- Memory Card Reader
- Yes (SD Card)
- Black
- Integrated Options
- G-sensor
- Security
- Administrator password, system password, hard drive password, MIMO technology
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- Power adapter, active pen
- Localization
- 1.53 kg
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
