TravelMate B117-M-C9UR notebook is designed to enhance the learning experience. From its robust construction to solid features, it helps maximize the potential of the classroom.
Acer TeachSmart
Make classroom participation more fun with Acer TeachSmart multicolored LED lights. For example, teachers can pose multiple choice questions to the class, and students can answer them in real-time with corresponding colored lights for all to see. -
Great for collaborating
This notebook facilitates group work with a lightweight form factor and a screen that opens 180° for easy collaboration. Also with 802.11ac 2x2 wireless antennas, wireless connectivity is fast and smooth. -
Tough and sturdy
It is protected from bumps and drops with a robust rubber strip, while its keyboard is resistant to accidental spills. What's more, its hinge has been designed to withstand a plenty of lid openings. -
Better input and navigation
Students will enjoy smoother swiping, scrolling, and zooming. Acer chiclet keyboard offers great travel distance and solid tactile feedback for a reliable and responsive typing experience.
- Acer TravelMate B117-M-C9UR - 11.6" - Intel Celeron - N3050 - 4 GB RAM - 500 GB HDD - UK
- Product Type
- Notebook
- Operating System
- Win 10 Home 64-bit
- Processor
- Intel Celeron N3050 / 1.6 GHz, up to 2.16 GHz / 2 MB Cache
- Memory
- 4 GB DDR3L (provided memory is soldered)
- Storage
- 500 GB HDD / 5400 rpm
- Display
- 11.6" LED backlight 1366 x 768 / HD
- Graphics
- Intel HD Graphics
- Keyboard
- UK
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.2
- Battery
- 4-cell - up to 12 hours
- Security
- Trusted Platform Module (TPM) Security Chip
- Black
- 29.1 cm x 21.1 cm x 2.23 cm
- 1.45 kg
- Localisation
- Region: United Kingdom
- Environmental Standards
- - ENERGY STAR Qualified EPEAT Climate+
- Product Type
- Notebook
- Operating System
- Windows 10 Home 64-bit Edition
Processor / Chipset
- CPU
- Max Turbo Speed
- 2.16 GHz
- Number of Cores
- Dual-Core
- Cache
- L2 - 2 MB
- 64-bit Computing
- Intel Burst Technology
- RAM
- 4 GB (provided memory is soldered)
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz
- Form Factor
- SO-DIMM 204-pin
Storage
- Main Storage
- 500 GB HDD SATA / 5400 rpm
Display
- 11.6"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1366 x 768 (HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 220 cd/m²
- Anti-glare, ComfyView
Audio & Video
- Graphics Processor
- Intel HD Graphics
- Memory Allocation Technology
- Shared Video Memory (UMA)
- Camera
- Yes - 1280 x 720
- Camera Features
- HDR (High Dynamic Range), 720p HD movie recording
- Sound
- Stereo speakers, microphone
- High Definition Audio
Input
- Keyboard, touchpad
- Keyboard Layout
- UK
- Multi-gesture touch pad, Acer FineTip keyboard
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 7265 - M.2 Card
- Intel Wireless Display (WiDi)
- Technology
- 4-cell Lithium Ion
- Capacity
- 48 Wh
- Run Time
- Up to 12 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 19 V
Connections & Expansion
- Interfaces Details
- USB 2.0 , USB 3.0 , HDMI , Headphone/microphone combo jack
- Memory Card Reader
- Yes (SD Card)
- Black
- Security
- Security lock slot (cable lock sold separately), administrator password, system password, hard drive password
- Included Accessories
- Power adapter
- Localization
- 1.45 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Climate+
- ENERGY STAR Certified
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.09 |
