The TravelMate B Series stands out in a crowd because of its unique and cool design. The large precision touchpad is optimized for accuracy and sensitivity, giving you a touch-gesture experience that's as smooth as on a touchscreen. An aluminum top cover with a hairline brush finish rounds out this laptops premium look.
Unique, smart design
The TravelMate B Series stands out in a crowd because of its unique and cool design. The large precision touchpad is optimized for accuracy and sensitivity, giving you a touch-gesture experience that's as smooth as on a touchscreen. An aluminum top cover with a hairline brush finish rounds out this laptops premium look. -
Productivity on the go
It's thin and light, so you can tuck it in your bag and forget about it. Plus, it gives you longer battery life, which combines with impressive processing and huge storage for great productivity wherever you roam. It is designed to not require a cooling fan, so it runs cool and whisper-quiet, for a very comfortable user experience. -
Everything you need for work
The high dynamic range HD webcam ensures images are bright and visible, even against direct sunlight. With a full-sized keyboard, all the right ports including Gigabit LAN, multi-gesture touchpad, you can get a lot done wherever you go. Plus, the optimized speakers deliver audio similar to what you'd expect from larger laptops.
- Acer TravelMate B116-M-P5LW - 11.6" - Pentium N3700 - 4 GB RAM - 500 GB HDD
- Product Type
- Notebook
- Operating System
- Win 10 Home 64-bit
- Processor
- Intel Pentium N3700 / 1.6 GHz (2.4 GHz) / 2 MB Cache
- Memory
- 4 GB DDR3L (1 x 4 GB)
- Storage
- 500 GB HDD / 5400 rpm
- Display
- 11.6" LED backlight 1366 x 768 / HD
- Graphics
- Intel HD Graphics
- Integrated Webcam
- Networking
- Bluetooth, 802.11a/b/g/n/ac, Gigabit Ethernet
- Battery
- 3-cell
- Black
- 29.1 cm x 21.1 cm x 2.12 cm
- 1.39 kg
- Localisation
- Region: United Kingdom
- Product Type
- Notebook
- Operating System
- Windows 10 Home 64-bit Edition
Processor / Chipset
- CPU
- Max Turbo Speed
- 2.4 GHz
- Number of Cores
- Quad-Core
- Cache
- 2 MB
- 64-bit Computing
- Intel Burst Technology
- RAM
- 4 GB (1 x 4 GB)
- Max RAM Supported
- 8 GB
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz
- Form Factor
- SO-DIMM 204-pin
- Slots Qty
- 1
- Empty Slots
- 0
Storage
- Main Storage
- 500 GB HDD SATA / 5400 rpm
Display
- 11.6"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1366 x 768 (HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 220 cd/m²
- Anti-glare, ComfyView
Audio & Video
- Graphics Processor
- Intel HD Graphics
- Memory Allocation Technology
- Shared Video Memory (UMA)
- Camera
- Yes - 1280 x 720
- Camera Features
- 720p HD movie recording
- Sound
- Stereo speakers, microphone
- High Definition Audio
Input
- Keyboard, touchpad
- Multi-gesture touch pad, Acer FineTip keyboard
Communications
- Wireless
- Network Interface
- Gigabit Ethernet
- Technology
- 3-cell
- Capacity
- 3315 mAh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 19 V
Connections & Expansion
- USB 2.0 , USB 3.0 , HDMI , LAN , Headphone output
- Memory Card Reader
- Yes (SD Card)
- Black
- Security lock slot (cable lock sold separately), administrator password, system password, hard drive password
- Included Accessories
- Power adapter
- ACPI 5.0
- Localization
- 1.39 kg
