Acer T272HL 27" 1920x1080 5ms HDMI Touch LED Monitor
Quicklinx: 9L98WS00 Mfr#: UM.HT2EE.005
The 27" touch display is made for users whom appreciate state of the art technology and innovative design. It opens up the world of Windows 8 advantages of 10 point multi touch functionality. Thanks to the edgy design the working angle of the monitor can be adjusted from 5° to 60° to ensure comfort. Areas close to the edges are easy to touch thanks to ZeroFrame design and front glass. In addition to the latest digital connectivity options you can also connect and power your mobile devices via the USB3.0 hub. T272HL reproduces consistent and natural colors from all viewing angles, thanks to E-IPS panel technology. Rapid response times ensure the smoothest reproduction of even the fastest videos and a fast, accurate and natural touch experience. The future of monitor technology, all in one solution.
Acer T272HLbmjjz - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27" - touchscreen
Energy Class
Class A
Energy Consumption per Year
38 kWh
Power Consumption (On mode)
26 W
USB 3.0 hub
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Brightness
300 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA
Speakers
Integrated
Display Position Adjustments
Tilt
Voltage
AC 120/230 V
66 cm x 5 cm x 49.3 cm
7.1 kg
Environmental Standards
ENERGY STAR Qualified
MPR II
3-year warranty
Display Type
Energy Class
Class A
38 kWh
Diagonal Size
27"
Built-in Devices
USB 3.0 hub
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
eColor Management, Acer Adaptive Contrast Management (ACM), High Frame Rate Control (Hi-FRC), Mobile High-Definition Link (MHL), Zero Frame, 10-point multi-touch
66 cm x 5 cm x 49.3 cm - with stand
7.1 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
2 Watt
Input
Touchscreen
VGA , 2 x HDMI , USB 3.0 upstream , 3 x USB 3.0 downstream
Mechanical
Tilt
Tilt Angle
+10/+60
USB 3.0 port power off USB charging
1 x VGA cable , 1 x USB cable
MPR II
Power Supply
External
Input Voltage
AC 120/230 V
26 W
Power Consumption (Typical)
20.3 Watt
Power Consumption Stand by
490 mW
On / Off Switch
No
Dimensions & Weight Details
With stand - width: 66 cm - depth: 5 cm - height: 49.3 cm - weight: 7.1 kg , Without stand - width: 66 cm - depth: 3.8 cm - height: 47 cm - weight: 6.63 kg
Sustainability Information
ENERGY STAR Certified
Limited warranty - parts and labour - 3 years
Accessories (4)
9L98 StarTech.com Dual Monitor Mount - Stackable In Stock £226.92
9L98 StarTech.com TV/Monitor Arm - Wallmount In Stock £82.52
9L98 StarTech.com Monitor Arm - Heavy Duty In Stock £93.49
9L98 StarTech.com Monitor Desk Mount - Steel In Stock £50.26
Other bundles (1)
9L98 C2G 5m USB 2.0 A/B Cable - Black In Stock £5.09
