The 27" touch display is made for users whom appreciate state of the art technology and innovative design. It opens up the world of Windows 8 advantages of 10 point multi touch functionality. Thanks to the edgy design the working angle of the monitor can be adjusted from 5° to 60° to ensure comfort. Areas close to the edges are easy to touch thanks to ZeroFrame design and front glass. In addition to the latest digital connectivity options you can also connect and power your mobile devices via the USB3.0 hub. T272HL reproduces consistent and natural colors from all viewing angles, thanks to E-IPS panel technology. Rapid response times ensure the smoothest reproduction of even the fastest videos and a fast, accurate and natural touch experience. The future of monitor technology, all in one solution.
- Acer T272HLbmjjz - LED monitor - Full HD (1080p) - 27"
- LED-backlit LCD monitor - 27" - touchscreen
- Energy Class
- Class A
- Energy Consumption per Year
- 38 kWh
- Power Consumption (On mode)
- 26 W
- USB 3.0 hub
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Brightness
- 300 cd/m²
- Contrast Ratio
- 100000000:1 (dynamic)
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, VGA
- Speakers
- Integrated
- Tilt
- Voltage
- AC 120/230 V
- Black
- 66 cm x 5 cm x 49.3 cm
- 7.1 kg
- Environmental Standards
- ENERGY STAR Qualified
- MPR II
- 3-year warranty
- Display Type
- Energy Class
- Class A
- 38 kWh
- Diagonal Size
- 27"
- Built-in Devices
- USB 3.0 hub
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 5 ms
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- eColor Management, Acer Adaptive Contrast Management (ACM), High Frame Rate Control (Hi-FRC), Mobile High-Definition Link (MHL), Zero Frame, 10-point multi-touch
- Black
- 66 cm x 5 cm x 49.3 cm - with stand
- 7.1 kg
Audio
- Speakers - stereo - integrated
- Output Power / Channel
- 2 Watt
Input
- Touchscreen
- VGA , 2 x HDMI , USB 3.0 upstream , 3 x USB 3.0 downstream
Mechanical
- Tilt
- Tilt Angle
- +10/+60
- USB 3.0 port power off USB charging
- Cables Included
- 1 x VGA cable , 1 x USB cable
- MPR II
- Power Supply
- External
- Input Voltage
- AC 120/230 V
- 26 W
- Power Consumption (Typical)
- 20.3 Watt
- Power Consumption Stand by
- 490 mW
- On / Off Switch
- No
- Dimensions & Weight Details
- With stand - width: 66 cm - depth: 5 cm - height: 49.3 cm - weight: 7.1 kg , Without stand - width: 66 cm - depth: 3.8 cm - height: 47 cm - weight: 6.63 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - parts and labour - 3 years
Accessories (4)
StarTech.com Dual Monitor Mount - Stackable | In Stock | £226.92 |
StarTech.com TV/Monitor Arm - Wallmount | In Stock | £82.52 |
StarTech.com Monitor Arm - Heavy Duty | In Stock | £93.49 |
StarTech.com Monitor Desk Mount - Steel | In Stock | £50.26 |
Other bundles (1)
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.09 |
