The innovative 23" touch display is made for users who appreciate state of the art technology and innovative design. Thanks to the edgy design the working angle of the monitor can be adjusted from 5° to 60° to ensure comfort. Areas close to the edges are easy to touch thanks to ZeroFrame design and front glass. In addition to the digital connectivity options you can also connect and power your mobile devices via the USB 3.0 hub. T232HL reproduces consistent and natural colors from all viewing angles, thanks to E-IPS panel technology. Rapid response times ensure the smoothest reproduction of even the fastest videos and a fast, accurate and natural touch experience.
Ten-point multi-touch
Ten-point multi-touch is a significant improvement on traditional two-finger multi-touch because it senses ten different touch positions on the screen, and thus allows you to pinch-to-zoom, rotate images, and scroll through webpages. -
Tilt angle of up to 60 degrees
Interact with this monitor from different angles. See it all the way to 60 degrees for control by touch from above. -
Full HD LED monitor
The 1920x1080 resolution of this LED monitor delivers excellent detail, making it perfect for advanced HD productivity and multimedia applications. LED monitors also consume less power and last longer than those with CCFL lamps. In addition, this monitor is mercury-free, making it safer for you and the environment. -
Digital connectivity
HDMI delivers exceptional high-definition viewing and gives the best-quality uncompressed video. DVI ports maximize the connection quality between LCD monitors and video graphics cards in PCs and other digital sources. -
SuperSpeed USB 3.0 port with charging
Transfer data to and from external devices ten times faster than USB 2.0. The USB ports on these monitors can be used to charge peripheral devices. -
The best possible color reproduction, paired with large viewing angles, makes this monitor the ideal companion for people looking at top performance, without any compromises. Clear images and fast response time, achieved thanks to advanced technology, are now at your service.
- Acer T232HLAbmjjz - LED monitor - Full HD (1080p) - 23"
- LED-backlit LCD monitor - 23" - touchscreen
- Energy Class
- Class B
- Energy Consumption per Year
- 38 kWh
- Power Consumption (On mode)
- 26 W
- USB 3.0 hub
- Panel Type
- E-IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Brightness
- 300 cd/m²
- Contrast Ratio
- 100000000:1 (dynamic)
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, VGA, MHL
- Speakers
- Integrated
- Tilt
- Voltage
- AC 120/230 V
- Black
- Dimensions (WxDxH) - without stand
- 57.37 cm x 3.8 cm x 42.01 cm
- 5.16 kg
- Localisation
- United Kingdom, Europe, EMEA
- Environmental Standards
- ENERGY STAR Qualified
- MPR II
- 2-year warranty
- Display Type
- Energy Class
- Class B
- 38 kWh
- Diagonal Size
- 23"
- Built-in Devices
- USB 3.0 hub
- Panel Type
- E-IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 5 ms
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- HDCP, eColor Management, Acer Adaptive Contrast Management (ACM), Mobile High-Definition Link (MHL), 10-point multi-touch
- Black
- 57.37 cm x 3.8 cm x 42.01 cm - without stand
- 5.16 kg
Audio
- Speakers - stereo - integrated
- Output Power / Channel
- 1.5 Watt
Input
- Touchscreen
- VGA , 2 x MHL / HDMI (HDCP) , USB 3.0 upstream , 3 x USB 3.0 downstream
Mechanical
- Tilt
- Tilt Angle
- 60
- VESA Mounting Interface
- Cables Included
- 1 x HDMI cable , 1 x VGA cable , 1 x USB cable
- MPR II
- Localisation
- Power Supply
- External
- Input Voltage
- AC 120/230 V
- 26 W
- Power Consumption (Typical)
- 20.9 Watt
- Power Consumption Stand by
- 490 mW
- Power Consumption Sleep
- 480 mW
- On / Off Switch
- No
- Dimensions & Weight Details
- With stand - width: 57.37 cm - depth: 5 cm - height: 45.5 cm - weight: 5.7 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 2 years
