Whether you're in the mood for work or play, the Switch One 10 has a mode for it. Choose from four modes - notebook mode for typing, pad mode for using touch, and tent and display modes for entertainment.
Snap on, snap off
A magnetic hinge design makes switching between modes easy. It doesn't have awkward mechanical connectors, so you can snap the tablet and keyboard together, or pull them apart, easily. -
See it better
With a crisp display, everything will look clear. Plus with IPS technology, you won't lose any details or color saturation when viewing the screen from wide angles. -
Feel the metal
The Switch One 10 features a design that's sophisticated, sleek and simple. Its brushed-metal cover gives it a unique and refined look that isn't overpowering, and also has a nice tactile feel to it.
- Acer Switch One 10 SW1-011-166Z - 10.1" - Intel Atom x5 - Z8350 - 2 GB RAM - 64 GB eMMC - UK
- Product Type
- Tablet - with keyboard dock
- Operating System
- Win 10 Home 32-bit
- Processor
- Intel Atom x5 Z8350 / 1.44 GHz, up to 1.92 GHz / 2 MB Cache
- Memory
- 2 GB DDR3L (provided memory is soldered)
- Storage
- 64 GB eMMC
- Display
- 10.1" LED backlight touchscreen 1280 x 800 / WXGA
- Graphics
- Intel HD Graphics
- Input Device
- Touchpad, detachable keyboard
- Keyboard
- UK
- Integrated Webcam
- Networking
- Bluetooth, 802.11b/g/n
- Battery
- 2-cell - up to 10 hours
- G-sensor
- Dockable
- Black, iron
- Dimensions (WxDxH) - tablet
- 25.9 cm x 18.05 cm x 0.965 cm
- 680 g
- Localisation
- Region: United Kingdom
- Environmental Standards
- - EPEAT Climate+
- Product Type
- Operating System
- Windows 10 Home 32-bit Edition
Processor / Chipset
- CPU
- Max Turbo Speed
- 1.92 GHz
- Number of Cores
- Quad-Core
- Cache
- L2 - 2 MB
- 64-bit Computing
- Intel Burst Technology
- RAM
- 2 GB (provided memory is soldered)
- Technology
- DDR3L SDRAM
Storage
- Main Storage
- 64 GB eMMC
Display
- 10.1" - IPS
- LCD Backlight Technology
- LED backlight
- Touchscreen
- Yes (multi-touch)
- Resolution
- 1280 x 800 (WXGA)
- Widescreen
- Image Brightness
- 300 cd/m²
- HDCP, glare, CineCrystal
Audio & Video
- Graphics Processor
- Intel HD Graphics
- Memory Allocation Technology
- Shared Video Memory (UMA)
- Camera
- Yes - 1600 x 1200 (rear), 1600 x 1200 (front)
- Resolution
- 2 Megapixel (rear), 2 Megapixel (front)
- Camera Features
- 720p HD movie recording
- Sound
- Stereo speakers, microphone
Input
- Keyboard Layout
- UK
- Multi-gesture touch pad, Acer FineTip keyboard
Communications
- Wireless
- Technology
- 2-cell lithium polymer
- Capacity
- 31.2 Wh
- Run Time
- Up to 10 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 15 Watt, 5 V, 3 A
Connections & Expansion
- Interfaces Details
- Micro-USB 2.0 , Micro-HDMI , Headphone/microphone combo jack , Dock , USB 2.0 (on keyboard dock)
- Memory Card Reader
- Yes (microSD)
- Black, iron
- Case Material
- Anodised aluminium
- Integrated Options
- G-sensor
- Dockable
- Volume control
- Included Accessories
- Power adapter
- Localization
- 680 g
- Dimensions (WxDxH) / Weight Details
- 25.9 cm x 18.05 cm x 0.965 cm / 680 g - tablet , 25.9 cm x 19.26 cm x 2.065 cm / 1.26 kg - tablet with keyboard
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Climate+
