This thin and light device slips into your bag and disappears, only to reappear when you need to get work done. The full-size keyboard also features deep key travelling depth (1.4mm) for comfy and accurate typing. Adjust the kickstand to tilt the screen to the exact angle you need.
Fluidly versatile
The centerpiece of the Aspire Switch 12 is its convertible multiple mode design that rolls five modes into one, making it more of a 5-in-1 than a 2-in-1. The five handy configurations include notebook, pad, display, tent and desktop modes, providing a mode for practically any need. -
Dashing display
With a big 12.5" screen, the Aspire Switch 12 sports an excellent display with technologies that let you see everything clearly from almost any angle, with vivid colors and detail, even in bright sunlight. The highly responsive touchscreen also has an effective anti-fingerprint treatment that greatly reduces unsightly smudges. -
One-of-a-kind kickstand
The Aspire Switch 12's distinctive kickstand design is at the core of its multi-mode capability, housing and functioning as the connector to the detachable keyboard which works as a connected keyboard in some modes and a wireless one in others. -
Distinctive keyboard
With several unique features, the Aspire Switch 12's keyboard deserves mention. In addition to offering full-size typing comfort and wireless capabilities, it has a built-in mouse stick in the middle, instead of a trackpad, providing a convenient pointing experience and space saving benefits. -
Durable design
Designed for all-round durability, the Aspire Switch 12 uses next-generation Corning Gorilla Glass to protect the display and has a latch-less magnetic keyboard connector tab design for easy mode switching, while offering a sturdy mechanical connection. It also features a whisper quiet, fan-less design that complements the very low power consumption processor.
- Acer Switch Alpha 12 SA5-271P-57GQ - 12" - Intel Core i5 - 6200U - 8 GB RAM - 256 GB SSD
- Product Type
- Tablet - with detachable keyboard
- Operating System
- Win 10 Pro 64-bit
- Processor
- Intel Core i5 (6th Gen) - 6200U / 2.3 GHz, up to 2.8 GHz / 3 MB Cache
- Memory
- 8 GB LPDDR3
- Storage
- 256 GB SSD
- Display
- 12" LED backlight touchscreen 2160 x 1440 / Full HD Plus
- Graphics
- Intel HD Graphics 520
- Input Device
- Touchpad, detachable keyboard, stylus
- Integrated Webcam
- Networking
- Bluetooth 4.0, 802.11a/b/g/n/ac
- Battery
- 2-cell - up to 8 hour(s)
- Ambient light sensor, digital compass, gyro sensor, G-sensor
- Security
- Trusted Platform Module (TPM) Security Chip
- Dimensions (WxDxH) - tablet
- 29.21 cm x 20.14 cm x 0.95 cm
- 900 g
- Environmental Standards
- - EPEAT Climate+
- Product Type
- Operating System
- Windows 10 Pro 64-bit Edition
Processor / Chipset
- CPU
- Intel Core i5 (6th Gen) 6200U / 2.3 GHz
- Max Turbo Speed
- 2.8 GHz
- Number of Cores
- Dual-Core
- Cache
- 3 MB
- 64-bit Computing
- Intel Turbo Boost Technology 2.0
- RAM
- 8 GB
- Technology
- LPDDR3 SDRAM
Storage
- Main Storage
- 256 GB SSD SATA 6Gb/s
Display
- 12" - IPS
- LCD Backlight Technology
- LED backlight
- Touchscreen
- Yes (10-point multi-touch)
- Resolution
- 2160 x 1440 (Full HD Plus)
- Widescreen
- Image Aspect Ratio
- 3:2
- Image Brightness
- 350 cd/m²
- Glare, CineCrystal, Zero Air Gap technology
Audio & Video
- Graphics Processor
- Memory Allocation Technology
- Shared Video Memory (UMA)
- Camera
- Yes - 2592 x 1944
- Resolution
- 5 Megapixel (rear), 2 Megapixel (front)
- Camera Features
- Autofocus, 1080p Full HD movie recording
- Sound
- Stereo speakers, microphone
- Audio Features
- Output: Acer TrueHarmony technology
Input
- Multi-gesture touch pad, Acer FineTip keyboard
Communications
- Wireless
- Technology
- 2-cell Lithium Ion
- Capacity
- 37 Wh
- Run Time
- Up to 8 hour(s)
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 19 V
Connections & Expansion
- Interfaces Details
- USB-C 3.1 Gen 1 , Headphone/microphone combo jack , USB 3.0
- Memory Card Reader
- Yes (microSD, microSDHC, microSDXC)
- Case Material
- Anodised aluminium
- Integrated Options
- Security
- Fanless, liquid cooling system, volume control, non-slip rubber frame, Windows button, MU-MIMO technology, multi-position Kickstand
- Included Accessories
- Power adapter, keyboard, active pen
- 900 g
- Dimensions (WxDxH) / Weight Details
- 29.21 cm x 20.14 cm x 0.95 cm / 900 g - tablet , 29.21 cm x 20.14 cm x 1.585 cm / 1.25 kg - tablet with keyboard
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Climate+
