Acer Switch 12 Alpha SA5-271P i5-6200U 8GB 256GB SSD 12" Win 10 P
Quicklinx: C9TMWS00 Mfr#: NT.LCEEK.007
  • Core i5
  • IEEE 802.11n
  • Bluetooth 4.0
This thin and light device slips into your bag and disappears, only to reappear when you need to get work done. The full-size keyboard also features deep key travelling depth (1.4mm) for comfy and accurate typing. Adjust the kickstand to tilt the screen to the exact angle you need.
  • Fluidly versatile
    The centerpiece of the Aspire Switch 12 is its convertible multiple mode design that rolls five modes into one, making it more of a 5-in-1 than a 2-in-1. The five handy configurations include notebook, pad, display, tent and desktop modes, providing a mode for practically any need.
  • Dashing display
    With a big 12.5" screen, the Aspire Switch 12 sports an excellent display with technologies that let you see everything clearly from almost any angle, with vivid colors and detail, even in bright sunlight. The highly responsive touchscreen also has an effective anti-fingerprint treatment that greatly reduces unsightly smudges.
  • One-of-a-kind kickstand
    The Aspire Switch 12's distinctive kickstand design is at the core of its multi-mode capability, housing and functioning as the connector to the detachable keyboard which works as a connected keyboard in some modes and a wireless one in others.
  • Distinctive keyboard
    With several unique features, the Aspire Switch 12's keyboard deserves mention. In addition to offering full-size typing comfort and wireless capabilities, it has a built-in mouse stick in the middle, instead of a trackpad, providing a convenient pointing experience and space saving benefits.
  • Durable design
    Designed for all-round durability, the Aspire Switch 12 uses next-generation Corning Gorilla Glass to protect the display and has a latch-less magnetic keyboard connector tab design for easy mode switching, while offering a sturdy mechanical connection. It also features a whisper quiet, fan-less design that complements the very low power consumption processor.
Acer Switch Alpha 12 SA5-271P-57GQ - 12" - Intel Core i5 - 6200U - 8 GB RAM - 256 GB SSD
Tablet - with detachable keyboard
Operating System
Win 10 Pro 64-bit
Intel Core i5 (6th Gen) - 6200U / 2.3 GHz, up to 2.8 GHz / 3 MB Cache
8 GB LPDDR3
Storage
256 GB SSD
Display
12" LED backlight touchscreen 2160 x 1440 / Full HD Plus
Graphics
Intel HD Graphics 520
Input Device
Touchpad, detachable keyboard, stylus
Integrated Webcam
Bluetooth 4.0, 802.11a/b/g/n/ac
2-cell - up to 8 hour(s)
Ambient light sensor, digital compass, gyro sensor, G-sensor
Security
Trusted Platform Module (TPM) Security Chip
Dimensions (WxDxH) - tablet
29.21 cm x 20.14 cm x 0.95 cm
900 g
Environmental Standards
- EPEAT Climate+
Operating System
Windows 10 Pro 64-bit Edition
Processor / Chipset
CPU
Intel Core i5 (6th Gen) 6200U / 2.3 GHz
Max Turbo Speed
2.8 GHz
Number of Cores
Dual-Core
Cache
3 MB
64-bit Computing
Intel Turbo Boost Technology 2.0
RAM
8 GB
LPDDR3 SDRAM
Storage
Main Storage
256 GB SSD SATA 6Gb/s
Display
12" - IPS
LCD Backlight Technology
LED backlight
Touchscreen
Yes (10-point multi-touch)
Resolution
2160 x 1440 (Full HD Plus)
Widescreen
Image Aspect Ratio
3:2
Image Brightness
350 cd/m²
Glare, CineCrystal, Zero Air Gap technology
Audio & Video
Graphics Processor
Memory Allocation Technology
Shared Video Memory (UMA)
Camera
Yes - 2592 x 1944
Resolution
5 Megapixel (rear), 2 Megapixel (front)
Camera Features
Autofocus, 1080p Full HD movie recording
Sound
Stereo speakers, microphone
Audio Features
Output: Acer TrueHarmony technology
Input
Multi-gesture touch pad, Acer FineTip keyboard
Communications
Wireless
2-cell Lithium Ion
37 Wh
Run Time
Up to 8 hour(s)
AC Adapter
Input
Output
45 Watt, 19 V
Connections & Expansion
Interfaces Details
USB-C 3.1 Gen 1 , Headphone/microphone combo jack , USB 3.0
Memory Card Reader
Yes (microSD, microSDHC, microSDXC)
Case Material
Anodised aluminium
Integrated Options
Security
Fanless, liquid cooling system, volume control, non-slip rubber frame, Windows button, MU-MIMO technology, multi-position Kickstand
Power adapter, keyboard, active pen
900 g
Dimensions (WxDxH) / Weight Details
29.21 cm x 20.14 cm x 0.95 cm / 900 g - tablet , 29.21 cm x 20.14 cm x 1.585 cm / 1.25 kg - tablet with keyboard
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Climate+
