The Acer Switch Alpha 12 features a portable form factor - adjustable display and full-sized keyboard help you stay productive while mobile.
Adjustable kickstand
Adjust the kickstand up to 165° and get the perfect screen angle. Its rubber anti-slip strip ensures the screen stays put. -
Full-sized keyboard
The full-sized magnetic snap-on keyboard is raised for comfy typing and doubles as a screen cover. -
Quiet and powerful
The Acer LiquidLoop cooling keeps the CPU performance up and doesn't generate whining fan noise.
- Acer Switch Alpha 12 SA5-271P-56UH - 12" - Intel Core i5 - 6200U - 4 GB RAM - 128 GB SSD - UK
- Product Type
- Tablet - with detachable keyboard
- Operating System
- Win 10 Pro 64-bit
- Processor
- Intel Core i5 (6th Gen) - 6200U / 2.3 GHz, up to 2.8 GHz / 3 MB Cache
- Memory
- 4 GB LPDDR3
- Storage
- 128 GB SSD
- Display
- 12" LED backlight touchscreen 2160 x 1440 / Full HD Plus
- Graphics
- Intel HD Graphics 520
- Input Device
- Digitizer, touchpad, digital pen, detachable keyboard
- Keyboard
- UK
- Integrated Webcam
- Networking
- Bluetooth 4.0, 802.11a/b/g/n/ac
- Battery
- 2-cell - up to 8 hours
- Ambient light sensor, digital compass, gyro sensor, G-sensor
- Security
- Trusted Platform Module (TPM) Security Chip
- Grey
- Dimensions (WxDxH) - tablet
- 29.21 cm x 20.14 cm x 0.95 cm
- 900 g
- Localisation
- Region: United Kingdom
- Environmental Standards
- - EPEAT Climate+
- Limited warranty - 1 year - pick-up and return , Traveller warranty - 1 year
- Product Type
- Operating System
- Windows 10 Pro 64-bit Edition
Processor / Chipset
- CPU
- Intel Core i5 (6th Gen) 6200U / 2.3 GHz
- Max Turbo Speed
- 2.8 GHz
- Number of Cores
- Dual-Core
- Cache
- 3 MB
- 64-bit Computing
- Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
- RAM
- 4 GB
- Technology
- LPDDR3 SDRAM
Storage
- Main Storage
- 128 GB SSD
Display
- 12" - IPS
- LCD Backlight Technology
- LED backlight
- Touchscreen
- Yes (10-point multi-touch)
- Resolution
- 2160 x 1440 (Full HD Plus)
- Widescreen
- Image Aspect Ratio
- 3:2
- Image Brightness
- 350 cd/m²
- Glare, CineCrystal, Zero Air Gap technology
Audio & Video
- Graphics Processor
- Memory Allocation Technology
- Shared Video Memory (UMA)
- Camera
- Yes - 2592 x 1944
- Resolution
- 5 Megapixel (rear), 2 Megapixel (front)
- Camera Features
- Autofocus, 1080p Full HD movie recording
- Sound
- Stereo speakers, microphone
- Audio Features
- Output: Acer TrueHarmony technology
Input
- Keyboard Layout
- UK
- Multi-gesture touch pad, Acer FineTip keyboard
Communications
- Wireless
- Wireless Controller
- M.2 Card
- Technology
- 2-cell lithium polymer
- Capacity
- 37 Wh
- Run Time
- Up to 8 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 19 V
Connections & Expansion
- Interfaces Details
- USB-C 3.1 Gen 1 , Headphone/microphone combo jack , USB 3.0
- Memory Card Reader
- Yes (microSD, microSDHC, microSDXC)
- Grey
- Case Material
- Anodised aluminium
- Integrated Options
- Security
- Fanless, liquid cooling system, volume control, non-slip rubber frame, Windows button, MU-MIMO technology, multi-position Kickstand
- Included Accessories
- Power adapter, keyboard, active pen
- Localization
- 900 g
- Dimensions (WxDxH) / Weight Details
- 29.21 cm x 20.14 cm x 0.95 cm / 900 g - tablet , 29.21 cm x 20.14 cm x 1.585 cm / 1.25 kg - tablet with keyboard
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Climate+
