Versatile, practical and powerful, the Acer Aspire Switch 10 E provides the perfect blend of multimedia fun and serious productivity.
The shape-shifting Aspire Switch 10 E has a detachable keyboard which can be attached and removed with a simple push or pull. It can be switched between four different modes - notebook, tablet, tent and display - depending on which is most convenient for your needs.
It's equipped with a 1.33GHz Intel Atom processor for enhanced graphics and gaming performance, 2GB RAM and a generous 64GB of hard drive storage space. Its two-cell battery provides up to 12 hours of power, so you'll have more than enough time to get that essential work done while you're on the move.
This Acer 10-inch tablet also comes in a range of cool colours, so you can choose the one that suits your personal style. It also features an HD screen with IPS technology, so you're guaranteed a great view whichever angle you're looking at it from.
Fluidly elegant
The Aspire Switch 10 knows design doesn't only live in a static image. Design lives in use. It is the feeling of the metal under fingers, a smooth release, a conveniently slim profile. Acer Snap Hinge design is flipping, folding, docking, detaching and all of the activities that ensue. -
Delightfully productive
The Aspire Switch 10's processor and Microsoft InstantGo means a smooth, fast experience and less time wasted. -
Stunningly vibrant
The Aspire Switch 10 makes visuals enjoyable in any situation. From a game between airport gates to a TV show caught between classes to an interactive children's book before goodnight, the Zero Air Gap (direct bonding) and IPS technology offer a stunning display for one or many. -
Immensely adaptable
Use the Aspire Switch 10 as a portable tablet, type with its keyboard for productivity, pivot its screen to share a presentation with others, or flip it to watch a movie when space is limited. Switch between laptop, tablet, display screen and tent modes to enhance your work and play. -
Extraordinarily bright
Whether you're an indoors person, an outdoors person, or a bit of both, the Aspire Switch 10 is designed to be used everywhere you go. Its LumiFlex display technology provides optimized color control that lets you watch videos and share photos even under the sun.
- Acer Aspire Switch 10 E SW3-013-1041 - 10.1" - Intel Atom - Z3735F - 2 GB RAM - 64 GB eMMC
- Product Type
- Tablet - with keyboard dock
- Operating System
- Win 10 Home 32-bit
- Processor
- Intel Atom Z3735F / 1.33 GHz, up to 1.83 GHz / 2 MB Cache
- Memory
- 2 GB DDR3L (provided memory is soldered)
- Storage
- 64 GB eMMC
- Display
- 10.1" LED backlight touchscreen 1280 x 800 / WXGA
- Graphics
- Intel HD Graphics
- Input Device
- Touchpad, detachable keyboard
- Integrated Webcam
- Networking
- 802.11b/g/n, Bluetooth 4.0
- Battery
- 2-cell - up to 12 hours
- Ambient light sensor, G-sensor
- Dockable
- Black, white
- Dimensions (WxDxH) - tablet
- 26.2 cm x 18 cm x 1.095 cm
- 630 g
- Localisation
- Region: United Kingdom
- Environmental Standards
- Product Type
- Operating System
- Windows 10 Home 32-bit Edition
Processor / Chipset
- CPU
- Max Turbo Speed
- 1.83 GHz
- Number of Cores
- Quad-Core
- Cache
- L2 - 2 MB
- 64-bit Computing
- Intel Burst Technology
- RAM
- 2 GB (provided memory is soldered)
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz
Storage
- Main Storage
- 64 GB eMMC
Display
- 10.1" - IPS
- LCD Backlight Technology
- LED backlight
- Touchscreen
- Yes (10-point multi-touch)
- Resolution
- 1280 x 800 (WXGA)
- Widescreen
- Image Aspect Ratio
- 16:10
- Image Brightness
- 350 cd/m²
- HDCP, glare, CineCrystal, Mercury free
Audio & Video
- Graphics Processor
- Intel HD Graphics
- Memory Allocation Technology
- Shared Video Memory (UMA)
- Camera
- Yes - 1600 x 1200 (rear), 1600 x 1200 (front)
- Resolution
- 2 Megapixel (rear), 2 Megapixel (front)
- Camera Features
- 720p HD movie recording
- Sound
- Stereo speakers, microphone
Input
- Multi-gesture touch pad, Acer FineTip keyboard
Communications
- Wireless
- Wireless Controller
- M.2 Card
- Technology
- 2-cell lithium polymer
- Capacity
- 30 Wh
- Run Time
- Up to 12 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 10 Watt, 5.35 V, 2 A
Connections & Expansion
- Interfaces Details
- Micro-USB 2.0 , Micro-HDMI , Headphone/microphone combo jack , Dock , USB 2.0 (on keyboard dock)
- Memory Card Reader
- Yes (microSD, microSDHC, microSDXC)
- Black, white
- Integrated Options
- Dockable
- Volume control
- Included Accessories
- Power adapter
- ACPI 5.0
- Localization
- 630 g
- Dimensions (WxDxH) / Weight Details
- 26.2 cm x 18 cm x 1.095 cm / 630 g - tablet , 26.2 cm x 18 cm x 2.285 cm / 1.2 kg - tablet with keyboard
Sustainability Information
- TCO Certified
