Switching is a snap
With its brilliant Acer Snap Hinge, this trendy and compact 2-in-1 laptop transforms into four different devices, simply and incredibly smoothly. Add to that its long battery life, and you have a partner for serious work and play - the perfect blend of a laptop's productivity and a tablet's multimedia fun. -
Versatile shape-shifter
This device's perfectly designed Acer Snap Hinge lets you snap the keyboard part on or off with a simple push or pull. Switch effortlessly between four very useful modes: notebook, tablet, tent, and display. -
Powerful producer
An Intel quad-core processor gives ample power for serious work and fun, and long battery life lets you compute on the go throughout the day. -
Data protector
Acer SwitchLock lets you lock this keyboard dock's HDD so it only works with the tablet part. Use the tablet as the HDD's key - simply snap the tablet off the keyboard to lock the HDD. All your HDD data is now protected and can't be stolen. Simply snap the tablet back on to unlock all that data. -
Friend of your eyes
This device features Acer VisionCare, so you can switch on Acer BluelightShield to reduce stress-causing blue light when you need to look at the screen for long periods. Acer LumiFlex auto-boosts contrast when you use this device in direct sunlight - no more squinting when you step outside. -
Great entertainer
The HD screen features IPS technology, so you get clear images when viewing from any angle. The screen is also made of ultra-tough Gorilla Glass, which protects against scratches and also makes scratches less visible. Dual speakers deliver serious sound and work with dual cameras to ensure great video calls.
- Acer Aspire Switch 10 E SW3-013-11GC - 10.1" - Intel Atom - Z3735F - 2 GB RAM - 32 GB eMMC
- Product Type
- Tablet - with keyboard dock
- Operating System
- Win 10 Home 32-bit
- Processor
- Intel Atom Z3735F / 1.33 GHz, up to 1.83 GHz / 2 MB Cache
- Memory
- 2 GB DDR3L (provided memory is soldered)
- Storage
- 32 GB eMMC
- Display
- 10.1" LED backlight touchscreen 1280 x 800 / WXGA
- Graphics
- Intel HD Graphics
- Input Device
- Touchpad, detachable keyboard
- Integrated Webcam
- Networking
- Bluetooth, 802.11b/g/n
- Battery
- 2-cell - up to 12 hours
- Ambient light sensor, G-sensor
- Dockable
- Black, pink
- Dimensions (WxDxH) - tablet
- 26.2 cm x 18 cm x 1.095 cm
- 630 g
- Localisation
- Region: United Kingdom
- Product Type
- Operating System
- Windows 10 Home 32-bit Edition
Processor / Chipset
- CPU
- Max Turbo Speed
- 1.83 GHz
- Number of Cores
- Quad-Core
- Cache
- L2 - 2 MB
- 64-bit Computing
- Intel Burst Technology
- RAM
- 2 GB (provided memory is soldered)
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz
Storage
- Main Storage
- 32 GB eMMC
Display
- 10.1" - IPS
- LCD Backlight Technology
- LED backlight
- Touchscreen
- Yes (10-point multi-touch)
- Resolution
- 1280 x 800 (WXGA)
- Widescreen
- Image Aspect Ratio
- 16:10
- Image Brightness
- 350 cd/m²
- HDCP, glare, CineCrystal, Mercury free
Audio & Video
- Graphics Processor
- Intel HD Graphics
- Memory Allocation Technology
- Shared Video Memory (UMA)
- Camera
- Yes - 1600 x 1200 (rear), 1600 x 1200 (front)
- Resolution
- 2 Megapixel (rear), 2 Megapixel (front)
- Camera Features
- 720p HD movie recording
- Sound
- Stereo speakers, microphone
Input
- Multi-gesture touch pad, Acer FineTip keyboard, precision touchpad
Communications
- Wireless
- Wireless Controller
- M.2 Card
- Technology
- 2-cell lithium polymer
- Capacity
- 30 Wh
- Run Time
- Up to 12 hours
- Battery Run Time
- Video playback: up to 12 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 10 Watt, 5.35 V, 2 A
Connections & Expansion
- Micro-USB 2.0 , Micro-HDMI , Headphone/microphone combo jack , Dock , USB 2.0 (on keyboard dock)
- Memory Card Reader
- Yes (microSD, microSDHC, microSDXC)
- Black, pink
- Integrated Options
- Dockable
- Volume control
- Included Accessories
- Power adapter
- ACPI 5.0
- Localization
- 630 g
- Dimensions (WxDxH) / Weight Details
- 26.2 cm x 18 cm x 1.095 cm / 630 g - tablet , 26.2 cm x 18 cm x 2.285 cm / 1.2 kg - tablet with keyboard
